68CommandoGuy 0 #1 Posted May 20, 2021 Hi all, I have a 1969 raider with a Tecumseh HH 100. It has a mechanical fuel pump. Does anyone know if this type pump can still be bought or if there is a rebuilding kit for it ? If not is there an alternative solution? Share this post Link to post Share on other sites
SylvanLakeWH 29,337 #2 Posted May 20, 2021 Not sure on your pump question, but I have been using a marine style primer bulb on my two with great success… starts are a breeze… 1 Share this post Link to post Share on other sites
RJR49 154 #3 Posted May 21, 2021 I recently replaced the mechanical pump on my Kohler K341 with an electric pump. I should have done it long ago 2 Share this post Link to post Share on other sites
DCwom 78 #4 Posted May 23, 2021 On 5/21/2021 at 1:22 PM, RJR49 said: I recently replaced the mechanical pump on my Kohler K341 with an electric pump. I should have done it long ago What ePump did you use? I've seen a few mentioned on the forum, but no consensus as to the one to buy. Share this post Link to post Share on other sites
RJR49 154 #5 Posted May 24, 2021 It was a Facet that I bought from NAPA. $80.00 bucks! Im sure that you can do better on line. It came with a filter which made it pretty long, But it works great. I guess you can leave the old pump in place to cover the hole in the block but I fab'd a gasket and plate. Share this post Link to post Share on other sites
Gregor 4,847 #6 Posted May 24, 2021 On 5/20/2021 at 4:53 PM, 68CommandoGuy said: Hi all, I have a 1969 raider with a Tecumseh HH 100. It has a mechanical fuel pump. Does anyone know if this type pump can still be bought or if there is a rebuilding kit for it ? If not is there an alternative solution? Do you have a spec # and pic of this fuel pump? Share this post Link to post Share on other sites
The Tuul Crib 7,340 #7 Posted May 24, 2021 Here is what l use. 1 1 Share this post Link to post Share on other sites
RJR49 154 #8 Posted May 24, 2021 I believe mine has a higher pressure output than the one shown by tuul crib. I'll have to check to see which one mine is but I think its a 0 - 10 PSI. I did read that 10 PSI is the Max joy want Share this post Link to post Share on other sites
peter lena 9,456 #9 Posted May 24, 2021 @ the tuul crib , got the exact model under a different name on the net , mounted up front near the original set up , super quiet with no issues at all , might do this to my other 2 horses, pete Share this post Link to post Share on other sites
