TJ5208 1,841 #1 Posted May 20, 2021 Had a question can I fill all four if you filled the fronts it would help with traction and control with tri ribs and ags Share this post Link to post Share on other sites
kasey54 305 #2 Posted May 20, 2021 Sure. Why not? I had weight on the front of my tiller tractor for the exact reason. Works great. Share this post Link to post Share on other sites
ebinmaine 79,688 #3 Posted May 20, 2021 You can absolutely fill the fronts. I run 4 oversized AND fluid filled tires on my Cinnamon Horse C160. Fronts have 5 gallons each, rears 7 gallons each. 24 gallons of Rimguard at 11 lb per gallon. Well over 250 lbs of fluid ALONE. 1 2 Share this post Link to post Share on other sites
MikMacMike 494 #4 Posted May 20, 2021 1 hour ago, ebinmaine said: You can absolutely fill the fronts. I run 4 oversized AND fluid filled tires on my Cinnamon Horse C160. Fronts have 5 gallons each, rears 7 gallons each. 24 gallons of Rimguard at 11 lb per gallon. Well over 250 lbs of fluid ALONE. To me that is exactly the way to go Ebin, so often when turning tight under sertain cercomstances the front will slide and I dont mean in just winter either.....Ill be doing exactly the same. Share this post Link to post Share on other sites
ebinmaine 79,688 #5 Posted May 20, 2021 2 minutes ago, MikMacMike said: front will slide Even with all that extra weight it STILL does on some uphill turns. I have a home-made weight that's built of a 6" round hunk o steel, and 2 chunks of lally column. Weighs about 110 lbs. Been thinking on how I could hang that out front too. Share this post Link to post Share on other sites
MikMacMike 494 #6 Posted May 20, 2021 1 minute ago, ebinmaine said: Even with all that extra weight it STILL does on some uphill turns. I have a home-made weight that's built of a 6" round hunk o steel, and 2 chunks of lally column. Weighs about 110 lbs. Been thinking on how I could hang that out front too. Couple of beers, ask the misses I bet theres an outcome....smiles. 2 Share this post Link to post Share on other sites
Herder 2,356 #7 Posted May 20, 2021 I like fluid and weights. I load almost all of my tires. Fronts and rears. 1 1 Share this post Link to post Share on other sites
Mike in NC 342 #8 Posted May 20, 2021 All four are filled on my Bronco 14. The fronts were filled when we got it. I put new ags on the front and filled with just air, it did not turn as good as the old filled turfs did. So I filled the ags. Turns a lot better. 1 Share this post Link to post Share on other sites
Roger R 473 #9 Posted May 21, 2021 Here's an alternative to loaded fronts 1 Share this post Link to post Share on other sites
TJ5208 1,841 #10 Posted May 21, 2021 I thought it would be a good idea Share this post Link to post Share on other sites
