Docwheelhorse 2,992 #1 Posted May 18, 2021 Hello all... been to a bunch of mom and pop hardware stores.... been to a current Toro/ retired Wheel Horse dealer... been to the "national brand" hardware stores... Haven't tried NAPA... WHERE ON GODS GREEN EARTH CAN I FIND THE WOODRUFF KEY FOR MY HUBS? I even looked on Epay... haven't tried McMaster Carr or similar yet either. Anybody know the part number? Thanks Tony Share this post Link to post Share on other sites
oliver2-44 11,758 #2 Posted May 18, 2021 (edited) You ACE or Hardware store that has all those grey parts drawers should have them Edited May 18, 2021 by oliver2-44 2 Share this post Link to post Share on other sites
peter lena 10,076 #3 Posted May 18, 2021 @Docwheelhorse, do you have an " INDUSTRIAL SUPPLY NEAR BY ? " they do a lot of sprockets , shives , pulleys , belts , bearings , probably also have the size key you need , pete Share this post Link to post Share on other sites
cschannuth 3,821 #4 Posted May 18, 2021 McMaster Carr has everything and you will have it at your house in one or two days but the shipping might cost more than the actual key. Share this post Link to post Share on other sites
76c12091520h 4,290 #5 Posted May 18, 2021 Try 937108. It's one of those "unique " to Wheel Horse pieces, at least in our area. We always had to get them straight from Toro/Wheelhorse 2 1 Share this post Link to post Share on other sites
Docwheelhorse 2,992 #6 Posted May 18, 2021 12 minutes ago, oliver2-44 said: You ACE or Hardware store that has all those grey parts drawers should have them They come close but don't have one this big... they have 1/4" ones but aren't big enough overall Share this post Link to post Share on other sites
pfrederi 21,184 #7 Posted May 18, 2021 Wheel Horse used at least 3 different keys over the years. The two smaller ones are usually 1/4 but length varied 1" long are #15 others are 1-3/8" #22 Both at McMaster or hardware store. if you have a GT14 or D series they use a #RX key The are very very hard to find even McMaster doesn't have them...i do if you need one 2 Share this post Link to post Share on other sites
pfrederi 21,184 #8 Posted May 18, 2021 See Wodruff key size chart pinned top of this section 1 Share this post Link to post Share on other sites
squonk 48,163 #9 Posted May 18, 2021 I had a 73 no name with 2 different size axle keys. Original owner said there was never an axle repair. Share this post Link to post Share on other sites
squonk 48,163 #10 Posted May 18, 2021 23 minutes ago, cschannuth said: McMaster Carr has everything and you will have it at your house in one or two days but the shipping might cost more than the actual key. Mc Master will sell you a pack. That way you can forget where they are when you need another one! 1 5 Share this post Link to post Share on other sites
Gregor 4,848 #11 Posted May 18, 2021 (edited) You don't say what tractor, or what transmission. C-141 Part # 937108 $3.49 Parts tree C-175 Same key same price Edited May 18, 2021 by Gregor Share this post Link to post Share on other sites
Docwheelhorse 2,992 #12 Posted May 18, 2021 Tractor is a GT1600 Work Horse... I should've looked but don't know if it has a 1" or 1 1/8th axels. I assumed the woodruff key was same for everything.... ooops Share this post Link to post Share on other sites
Herder 2,356 #13 Posted May 18, 2021 (edited) I've purchased an assorted size pack from Tractor Supply and was able to find the two I needed for my 1054. Squonk is right, it's not the first pack I've misplaced. Edited May 19, 2021 by Herder 2 Share this post Link to post Share on other sites
Gregor 4,848 #14 Posted May 18, 2021 9 minutes ago, Docwheelhorse said: Tractor is a GT1600 Work Horse... I should've looked but don't know if it has a 1" or 1 1/8th axels. I assumed the woodruff key was same for everything.... ooops They list 2 different keys for a GT-1600 The number I gave above, and, The other is NOT AVAILABLE . Share this post Link to post Share on other sites
Gregor 4,848 #15 Posted May 18, 2021 Per parts manual for 1984 GT-1600 Twin 8 Speed. 1 Share this post Link to post Share on other sites
squonk 48,163 #16 Posted May 18, 2021 Measure your keys. McMaster has the sizes listed right with the keys. Order a pack Install 2. Then put 2 at 4 different places in your shop. You're bound to run across them at some point! 4 Share this post Link to post Share on other sites
WHX?? 58,227 #17 Posted May 18, 2021 (edited) #15 woodruff ... any bigger hardware store should have them. MCC will have boatloads of them Edited May 18, 2021 by WHX24 Share this post Link to post Share on other sites
roadapples 6,987 #18 Posted May 18, 2021 2 hours ago, squonk said: Then put 2 at 4 different places in your shop. You're bound to run across them at some point! I've done that with tape measures... 4 Share this post Link to post Share on other sites
WHX?? 58,227 #19 Posted May 18, 2021 (edited) 8 minutes ago, roadapples said: I've done that with tape measures... I'll second that ....bought a dozen cheapys at HF and planted them, figured on growing a tape measure tree.... didn't work still have none ... Edited May 18, 2021 by WHX24 2 Share this post Link to post Share on other sites
squonk 48,163 #20 Posted May 18, 2021 22 minutes ago, WHX24 said: I'll second that ....bought a dozen cheapys at HF and planted them, figured on growing a tape measure tree.... didn't work still have none ... You prolly got the metric one anyway.. 3 Share this post Link to post Share on other sites
WHX?? 58,227 #21 Posted May 19, 2021 9 minutes ago, squonk said: You prolly got the metric one anyway.. Was trying to match the metric Cresent wrench... 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #22 Posted May 19, 2021 Have you tried lowes? Share this post Link to post Share on other sites
Docwheelhorse 2,992 #23 Posted May 21, 2021 Hello Everyone, thanks for the help... I will try to go back to the Toro dealer and see if the 937108 key is available... then will continue my local search / sit down and order them online. Home Depot, Lowes, Ace, True Value... Doit Right... etc.... all no gots. Close but too small is all I can find... Tony Share this post Link to post Share on other sites
Stormin 9,988 #24 Posted May 21, 2021 If push comes to shove, make your own. Round bar or similar, hacksaw and file. Share this post Link to post Share on other sites
stevasaurus 23,857 #25 Posted May 21, 2021 I've had them larger and used a 4" grinder and file to make them fit. Share this post Link to post Share on other sites
