Dan Piper 1 #1 Posted May 15, 2021 Good morning and thank you for allowing me on this site I restored a 1962 702 I'm almost done I just want to change the fluids I don't know the capacities and the types of fluids listed is there anyone out there that could steer me in the right direction either to buy a manual or to just tell me how to do it your help would be greatly appreciated Share this post Link to post Share on other sites
squonk 47,382 #2 Posted May 15, 2021 Engine Straight 30W Detergent for summer use. I use Rotella Gear box 80W90 gear oil 3 Share this post Link to post Share on other sites
peter lena 9,942 #4 Posted May 15, 2021 hello dan , welcome to the site, rotella 30 wt oil is probably the way to go , very well suited to you engine. also when you drain the rear end jack up the front end to increase its discharge , while at that raised point grease the front end 3 fittings , the grease should come out on top of the axel spindle . also grease the steering lower rack at frame level under dash . do you have a new shift boot ? you should . stops moisture entry to trans , capacity , 80-90 , 2 qts+ and measure dip stick , engine 2qts + measure as You go . also take the time to lubricate every movement point , like clutch set up , it should work seamlessly . pete 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,353 #5 Posted May 15, 2021 Welcome to the forum. Click on the picture in this link. Lots of info including 2 pages from the Lubrication guide. When it was printed the recommendations in it may have been changed to what was in the original manuals. Garry Share this post Link to post Share on other sites
Racinbob 13,040 #6 Posted May 15, 2021 I agree with the 30wt in the engine bit the K161only takes 1 1/4 quarts (40 oz). I would start with that and then go by the dipstick. 3 and 4 speed transmissions call for 1 1/2 quarts but you won't hurt it with 2. In my K-series Kohlers I use 30w year round . I use 80w90 in the transmission. In 1964 Wheel Horse issues a service bulletin recommending switching to 40w in the transmission. This was to help prevent the slide rails from messing up causing it to lock up in two gear. Shortly after that they revised the rails to achieve a proper fix. 3 Share this post Link to post Share on other sites
peter lena 9,942 #7 Posted May 15, 2021 @Racinbob, thanks for the ubication verification on that , after I put in my base refill on anything I regularly check as I go , also do that after a test run while looking for anything else I might have for gotten , pete 1 Share this post Link to post Share on other sites
Racinbob 13,040 #8 Posted May 15, 2021 That's a good way to go about it Pete. There's so much conflicting info out there. I found three different numbers for my K-91. Fortunately it had a dipstick. Share this post Link to post Share on other sites
lynnmor 8,899 #9 Posted May 15, 2021 If your your transmission oil comes out looking like a chocolate milkshake, you should flush it with diesel fuel. These tractors have a rubber boot that allows rain water to get in if they aren’t perfect. Share this post Link to post Share on other sites
Gregor 4,848 #10 Posted May 15, 2021 (edited) And the Kohler manual says 1 qt. ??????? Of course we are all assuming it has a stock K161S in it. Edited May 15, 2021 by Gregor Share this post Link to post Share on other sites
Dan Piper 1 #11 Posted May 15, 2021 I have a 1962 702 I'm looking to find out what gear oils and motor oils it takes and what the quantity is does anyone have a manual that can take a picture of or let me know how to do it I've restored it all it's ready to go I just want to change the fluids thank you in advance for your help Share this post Link to post Share on other sites
Racinbob 13,040 #12 Posted May 15, 2021 Treat it like they say to do with the A type oil pan. Put a quart in and check the dipstick. I'm betting that you will need to add another cup. Follow what they say on the previous page depending on the type of dipstick you have. Share this post Link to post Share on other sites
ebinmaine 79,688 #13 Posted May 15, 2021 I'm more familiar with the mid 60s to 70s but I'll try to help out. If the engine is the original Kohler it should use a straight 30 oil of SJ API rating. Several of the folks here use certain diesel oils with good result. I use Kinetix brand. The transmission fluid is just good old inexpensive 80w90 (or close) gear oil. Share this post Link to post Share on other sites
Dan Piper 1 #14 Posted May 16, 2021 Thanks very much ! 1 Share this post Link to post Share on other sites
Dan Piper 1 #15 Posted May 16, 2021 Thanks again for the response I just discovered another problem I don't know whether you've come across it or not but all of a sudden I can't shift from one gear to the other without shutting the machine off it'll just grind it's never done that before would you have any idea what that might be ? Share this post Link to post Share on other sites
Racinbob 13,040 #16 Posted May 16, 2021 (edited) I'm guessing you don't have the belt guard installed. It needs to be on in order for the drive belt to stop. Edited May 16, 2021 by Racinbob Share this post Link to post Share on other sites
Dan Piper 1 #17 Posted May 16, 2021 Thanks to everyone for all the comments I found one problem with it it looks like the transmission fluids never been changed it was only half a liter in it and it looked like coffee with cream in it decide belt guard is on it's still wants to grind going into gear but not as bad I put one liter of transmission fluid in it is that not enough I'm sorry I don't mean transmission fluid I mean gear fluid Share this post Link to post Share on other sites
