Wheel Horse 3D 3,822 #76 Posted May 22, 2021 Spacing and size look perfect on that test run, so bezel and back are currently printing in black on the new machine! 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #77 Posted May 23, 2021 Lens lightly frosted with 300 grit sand paper 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #78 Posted May 28, 2021 K i have the one lens done, but still iro ing out some print issues to make them print with less supervision.while im getting lined out, ill send lens #1 to @WheelhorseBob so he can do a test fit, etc. Bob, would ya like that lens clear or lightly frosted? 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #79 Posted May 28, 2021 Clear works for me and thank you very much! Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #80 Posted May 29, 2021 34 minutes ago, WheelhorseBob said: Clear works for me and thank you very much! And you can always sand it a little if youd prefer frosted later! Share this post Link to post Share on other sites
cschannuth 3,819 #81 Posted May 29, 2021 @Wheel Horse 3D I’ll take one too when available and you figure out the cost. 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #82 Posted May 29, 2021 Yes sir, I have you, and WH24x on the list, sticks in my mind there was one other . If ya need it BEFORE big show let me know! Share this post Link to post Share on other sites
cschannuth 3,819 #83 Posted May 29, 2021 45 minutes ago, Wheel Horse 3D said: Yes sir, I have you, and WH24x on the list, sticks in my mind there was one other . If ya need it BEFORE big show let me know! I won’t be at the big show but it’s no rush. Whatever works for you is fine with me. I’d like the lightly frosted version since the original is slightly opaque and my LEDs are pretty ugly. Thanks! 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #84 Posted May 29, 2021 16 minutes ago, cschannuth said: I won’t be at the big show but it’s no rush. Whatever works for you is fine with me. I’d like the lightly frosted version since the original is slightly opaque and my LEDs are pretty ugly. Thanks! Can do! And ill go light on the sanding, and you can sand a little more till its just right if ya like. Dont want to get them too frosted. 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #85 Posted May 29, 2021 Once I get the prints runnin smooth, I'll post em up in the store, and let everyone know. 1 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #86 Posted June 1, 2021 Made some progress yesterday getting the prints to line out, sometimes its just tinker tinker till its right. Got some of the smoothest layers ive ever printed layin down now. Should be able to see after work if the print went ok and how well the layers adhered etc., Prototype lens should be headed out to Bob today! 1 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #87 Posted June 1, 2021 Slight tweak on the length of the back plate, otherwise print settings look good! 1 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #88 Posted June 8, 2021 I have the prototype and will mount it to my hood later this week for a fitment test. Thank you Wheel Horse 3D!! 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #89 Posted June 8, 2021 3 hours ago, WheelhorseBob said: I have the prototype and will mount it to my hood later this week for a fitment test. Thank you Wheel Horse 3D!! Awesome, Thank you for your efforts in developing these! Just let us know how it goes and if I need to modify anything. Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #90 Posted June 11, 2021 Looks like I'm about 3/16 off horizontally and vertically. I'll be re-comparing to the example lens and adjusting that spacing accordingly! Thanks @WheelhorseBob! I'll get that corrected ASAP. Share this post Link to post Share on other sites
WheelhorseBob 1,550 #91 Posted June 12, 2021 Again, thank you for even trying this! Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #92 Posted June 12, 2021 Adjusted files last night, adjust spacing, enlarge holes, provide deeper countersink, make back plate holes a bit larger than front bezel holes. Now printing! 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #93 Posted June 19, 2021 Got it today! And here it is on my unrestored hood. The holes were very close. Keep in mind the screws they used were 6-32 and they had zero wiggle in them. Hopefully WH used a template to drill and they don’t vary much. Thanks again! Oh I spruced it up with new stainless fasteners of the original size. 2 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #94 Posted June 19, 2021 Thank you Bob! I did leave the back plate holes a bit bigger for easier alignment, and there should be a little meat left there to slightly enlarge the front holes if needed. The screw pockets look good. If ya ever want to frost the lens i did a little more testing on that ...and 300 grit front AND back seems about perfect. If anyone wants to gloss up their bezel, enamel paints work well on these plastics. Bob's is the natural finish and texture straight from the printer. 1 Share this post Link to post Share on other sites
cschannuth 3,819 #95 Posted June 20, 2021 5 minutes ago, Wheel Horse 3D said: Thank you Bob! I did leave the back plate holes a bit bigger for easier alignment, and there should be a little meat left there to slightly enlarge the front holes if needed. The screw pockets look good. If ya ever want to frost the lens i did a little more testing on that ...and 300 grit front AND back seems about perfect. If anyone wants to gloss up their bezel, enamel paints work well on these plastics. Bob's is the natural finish and texture straight from the printer. I’d still like to get a frosted one when you’re ready to sell/ship them. Looks great. 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #96 Posted June 20, 2021 Heres an example of the 300 grit front and back Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #97 Posted June 20, 2021 28 minutes ago, cschannuth said: I’d still like to get a frosted one when you’re ready to sell/ship them. Looks great. Thank you sir! Once I get the printers goin for the evening and get settled for the night, I'll add those to the store. Store can be found at the website link in my profile. 1 Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #98 Posted June 20, 2021 Got those added to the store! 1 Share this post Link to post Share on other sites
cschannuth 3,819 #99 Posted June 25, 2021 I received the lens and installed it last night and I think it looks better than the original with the frost. It actually covers up some of the inconsistencies in the headlight bucket and gives it a very clean look. Thanks @Wheel Horse 3D 2 Share this post Link to post Share on other sites
Wheel Horse 3D 3,822 #100 Posted June 27, 2021 Thanks Craig! 1 Share this post Link to post Share on other sites
