Mickwhitt 5,259 #1 Posted May 10, 2021 Hi all. Spotted this at my local auto paint store. Not seen it before but it looks promising if it is as good as it says. Anyone know of it, used it? 2 Share this post Link to post Share on other sites
Stormin 9,987 #2 Posted May 10, 2021 Sounds good but not come across it. 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #3 Posted May 10, 2021 5 minutes ago, Stormin said: Sounds good but not come across it. for sure if it works for fuel tanks. Share this post Link to post Share on other sites
seuadr 490 #4 Posted May 11, 2021 no idea - but here is a video of a guy lifting up his truck with chain made from various exposies? https://www.alloutdoor.com/2021/01/26/stuff-breaks-whats-best-epoxy-putty/ Share this post Link to post Share on other sites
rmaynard 17,113 #5 Posted May 11, 2021 When it comes to the plastic tanks on models like the C's, those are made of polyethylene. I have yet to see any type of epoxy that will stick to them. Let us know if you try one if those. Share this post Link to post Share on other sites
Handy Don 16,328 #6 Posted May 11, 2021 3 hours ago, rmaynard said: polyethylene. I have yet to see any type of epoxy that will stick Non-stick was one of the essential goals of the inventors! Only way to mend is with the right solvent and a compatible patch. (And breathing protection!) Share this post Link to post Share on other sites
rmaynard 17,113 #7 Posted May 11, 2021 56 minutes ago, Handy Don said: Non-stick was one of the essential goals of the inventors! Only way to mend is with the right solvent and a compatible patch. (And breathing protection!) Or plastic weld. 1 Share this post Link to post Share on other sites
Handy Don 16,328 #9 Posted May 12, 2021 4 hours ago, rmaynard said: Or plastic weld. Solvent and patch in one! Share this post Link to post Share on other sites
DennisThornton 4,773 #10 Posted May 12, 2021 18 hours ago, rmaynard said: When it comes to the plastic tanks on models like the C's, those are made of polyethylene. I have yet to see any type of epoxy that will stick to them. Let us know if you try one if those. Only way I know to fix poly is to heat to melting and weld it. 1 Share this post Link to post Share on other sites
