OutdoorEnvy 1,817 #1 Posted May 3, 2021 Anyone know the offset for rims marked 12x7ja? A pair are for sale here at a decent price but I can't find anything on google that lists the offset. Seller thinks it's a John Deere part number but I couldn't verify that. Pics look like the offset is in the ballpark so was curious if anyone has a pair or knows the offset. I'm wanting to run 23x9.5-12 tires and realized my 312-8 has the 12x5 rims. So looking to find a pair of 12x7's. Share this post Link to post Share on other sites
littleredrider 409 #2 Posted May 3, 2021 I have a pair of 7s I can get an accurate measurement, but thinking they are around 1 1/2 or so. Share this post Link to post Share on other sites
Lee1977 7,764 #3 Posted May 3, 2021 1 3/8" back set and that would be the same for the 8 1/2" rims. Share this post Link to post Share on other sites
pfrederi 21,145 #4 Posted May 3, 2021 WH motly used 1-3/8" backset. 2-3/8" was widely used by JD and others.... Share this post Link to post Share on other sites
clueless 3,438 #5 Posted May 3, 2021 Do you know for sure your 312 has 5 inch rims, pretty sure they didn't come with 5 inch. Share this post Link to post Share on other sites
Jeff-C175 7,211 #6 Posted May 3, 2021 25 minutes ago, clueless said: 5 inch rims I didn't think 5" rims are even a 'thing' ! 18 hours ago, OutdoorEnvy said: wanting to run 23x9.5-12 tires What size tires are on the 'alleged' 5" rims? Share this post Link to post Share on other sites
973Chuck 11 #7 Posted May 3, 2021 (edited) These are photos of 12 x 7 rims that came off of a 312-8. 1st photo: 12 x 7 JA 2nd photo: ~1 3/4” backspace 3rd photo: 0419725 stamp on backside Edited May 3, 2021 by 973Chuck Incorrect measurement 1 Share this post Link to post Share on other sites
973Chuck 11 #8 Posted May 3, 2021 Correction for 2nd photo: ~ 1 3/4 backspace - sorry about that. Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #9 Posted May 3, 2021 Measuring them they look like they are 6 inches at their widest width. Here is a pic of a number on the inside of the rim and the measurement is on the outside of the rim. Tires on them are 22x7.5-12. Is there a 6" wide rim? And if so would that run 9.5" wide tires? Share this post Link to post Share on other sites
pfrederi 21,145 #10 Posted May 3, 2021 (edited) 2 hours ago, Jeff-C175 said: I didn't think 5" rims are even a 'thing' ! What size tires are on the 'alleged' 5" rims? Yes there are 5" rims compared to 7 inch My 310-8 with he 22-7.5 had them ...original I am not sure but...they fit Edited May 3, 2021 by pfrederi Share this post Link to post Share on other sites
Jeff-C175 7,211 #11 Posted May 3, 2021 2 hours ago, OutdoorEnvy said: Is there a 6" wide rim? And if so would that run 9.5" wide tires? I think 6" is too narrow for a 9.5" tire. You'll probably get 'bulging' tread, some call it 'ballooning'. Share this post Link to post Share on other sites
clueless 3,438 #12 Posted May 4, 2021 If your tires are the 22x7.5x12 then your rims a probably the 5 inch. I've just never seen a 312 with the 22x7.5x12 tires on it. I know the 310 and 308 came with the smaller tires but not the 312, but you have what you have. Yes you can put the 9.5 wides on the rim, but like Jeff said they will be ballooning, which mean your not getting anymore actual ground contact the with the 7.5's they just look cooler. Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #13 Posted May 5, 2021 11 hours ago, clueless said: If your tires are the 22x7.5x12 then your rims a probably the 5 inch. I've just never seen a 312 with the 22x7.5x12 tires on it. I know the 310 and 308 came with the smaller tires but not the 312, but you have what you have. Yes you can put the 9.5 wides on the rim, but like Jeff said they will be ballooning, which mean your not getting anymore actual ground contact the with the 7.5's they just look cooler. Thanks for the input, that's why I was thinking these 12x7ja's would fit the offset to work well and then I can mount the 9.5" wide tires on them. I want to put some 6-12 AG tires on the 5 inch rims and have two rear sets. Figured it'd just add to the versatility of the tractor. 1 Share this post Link to post Share on other sites
OutdoorEnvy 1,817 #14 Posted May 6, 2021 Thanks for the help all. I did get the rims and the offset measured out to about 1.5" so they should work out good. Share this post Link to post Share on other sites
