Crazyredhorse 296 #1 Posted May 1, 2021 (edited) Dont know how you guys feel about links but this helped me it's a real pain to change and may help someone.one thing I can add use a long wrench on pulley nut on tensioner arm to relive remove or put on belt. https://outdoorpowerinfo.com/repairs/wheel_horse_hydro_252-h_drive_belt.asp Edited May 1, 2021 by Crazyredhorse 1 Share this post Link to post Share on other sites
mike avad 59 #2 Posted November 14, 2022 so what all part's need to be remove to replace this belt. I have a Briggs&stratton on my 525-H wheelhorse 1 Share this post Link to post Share on other sites
peter lena 9,779 #3 Posted November 18, 2022 @Crazyredhorse / @mike avad would also take advantage of the opportunity to service related idler pulleys and linkage areas , would re grease those pulleys , lubricate all those dry movement spots , penetrating lubricant , also red spray grease . every related movement point has to be free and easily moving . ironically those pictures are you problem and answer , belt tension point is probably your belt access removal / install point . never done one , but easy total view access is your best set up . make it better as you go . pete 1 Share this post Link to post Share on other sites
mike avad 59 #4 Posted December 10, 2022 thank you all for the help and reply's 1 Share this post Link to post Share on other sites
cJ_3D 9 #5 Posted June 23, 2024 (edited) On 4/30/2021 at 11:43 PM, Crazyredhorse said: Dont know how you guys feel about links but this helped me it's a real pain to change and may help someone.one thing I can add use a long wrench on pulley nut on tensioner arm to relive remove or put on belt. https://outdoorpowerinfo.com/repairs/wheel_horse_hydro_252-h_drive_belt.asp Hey @Crazyredhorse! I'm havin a heck of a time trying to figure out how to get tension off this belt to get it on or off. Where do you stick a wrench exactly or where do you pry to get the tensioner to move so you can get the belt on? It's been driving me nuts! Thanks! Edit: Hold the phone I may have found it! Looks like I was mistaken about which pulley was the tension. Found this exert from the transmission manual. Does this look correct? Maybe it will help someone else as well Edited June 24, 2024 by cJ_3D Update Share this post Link to post Share on other sites
