johnnymag3 2,634 #1 Posted April 29, 2021 Will the JD rim after being painted Almond....Bolt to a Wheel Horse? 23 x 9.50 x 12 thanks Share this post Link to post Share on other sites
shallowwatersailor 3,220 #2 Posted April 29, 2021 The setback may be different. You need to measure both manufacturer's setback and compare. 3 Share this post Link to post Share on other sites
ebinmaine 77,311 #3 Posted April 29, 2021 Most garden tractors use the same bolt pattern which is 5 lug by 4.5 in. However, Horses have a shallow backspacing and a lot of other brand rims don't bolt directly on because of contact issues from the inner Tire to areas on the Tractor such as brakes or linkages. 1 Share this post Link to post Share on other sites
johnnymag3 2,634 #4 Posted April 29, 2021 That was I was thinking too Eric...I will have him measure for me John 1 Share this post Link to post Share on other sites
johnnymag3 2,634 #5 Posted April 29, 2021 I wanted to be sure they were 4.5 also.... John Share this post Link to post Share on other sites
pfrederi 19,874 #6 Posted April 29, 2021 As long as you do not use chains or fat tires you can "Usually" (depends on the WH you are working on) get by with 2-3/8 backset JD used. 1 Share this post Link to post Share on other sites
ebinmaine 77,311 #7 Posted April 29, 2021 Actually now that I think about it you could also put spacers in there if those Wheels were some kind of awesome or a smoking deal like free. I keep a list of all the things you need to change over to spacers. Share this post Link to post Share on other sites
johnnymag3 2,634 #8 Posted April 29, 2021 Great....He wants 5 dollars for both, and they are rust free. I am looking to put them on my new to me 416-8 Single thumper 1 1 Share this post Link to post Share on other sites
johnnymag3 2,634 #9 Posted April 29, 2021 I am getting tractor heavyyyyyyyyyy.....Oh well....whats another one 1 1 Share this post Link to post Share on other sites
pfrederi 19,874 #10 Posted April 29, 2021 What is wrong with the wheel on there now??? Share this post Link to post Share on other sites
johnnymag3 2,634 #11 Posted April 29, 2021 Nothing really.....just want to put another style tire on it... Without swapping rubber Share this post Link to post Share on other sites
pfrederi 19,874 #12 Posted April 29, 2021 Don't go wide.... 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #13 Posted April 29, 2021 (edited) had bolens rims with ag's 23*10.5 they didn't fit, they where rubbing on the fueltank holder on my 312 But a smaller tire and it would have worked Edited April 29, 2021 by Maxwell-8 2 Share this post Link to post Share on other sites
Maxwell-8 4,370 #14 Posted April 29, 2021 59 minutes ago, johnnymag3 said: JD rim after being painted Almond VERY IMPORTANT VERY IMPORTANT can't stand that yellow 3 1 Share this post Link to post Share on other sites
Thor27 848 #15 Posted April 29, 2021 (edited) I have a set on a c-160 with 23 10.5 firestone ags. the set I have has 3 inches of back space. they imho fit perfect, but won't fit a newer tractor with the tank under the seat Edited April 30, 2021 by Thor27 add bs 2 Share this post Link to post Share on other sites
