rjg854 13,330 #51 Posted May 18, 2021 Looking good 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,279 #52 Posted May 18, 2021 Little help please… Was running well. Then no throttle. Idle to high no change. Runs fine idle but no throttle. So went through the adjustment process in manual and no change. Cable is also slipping and does not seem correct for the governor adjustment arm… anyone have a k 181 you could post some pics on what it should look like? Here’s some pics of my problem: Share this post Link to post Share on other sites
peter lena 10,030 #53 Posted May 18, 2021 @SylvanLakeWHe nice job on that, I also have a 82-c85 , bought it new in 82, coming on 40 years , been kept up and regularly serviced and upgraded . last major was 2 years ago , picked up a solid 12 hp magnum , made the swap , use it as my franken horse to experiment and trial on ideas . my plastic rear fender is hanging in the shed , went to steel years ago . my 3 horses have the same set up on everything , chassis, bearings, electrical , fuel system , once I find a problem fix i change that over to the others , makes for solid dependability, pete 1 Share this post Link to post Share on other sites
WHX?? 57,904 #54 Posted May 18, 2021 Throttle cable should be clamped to this arm. That arm can be moved by loosening the brass nut behind guv arm. That's what sets the max rpm. Check that the spring loop is in the slot of the plate with the holes in it. The other holes are for fine tweaking. 1 1 Share this post Link to post Share on other sites
WHX?? 57,904 #55 Posted May 18, 2021 7 HP but same difference 2 1 Share this post Link to post Share on other sites
peter lena 10,030 #56 Posted May 18, 2021 @WHX24, agree with your clamping , added a number of cable clamps to all my cables , and use the silicone SUPER LUBE , for lubricant , rated at -40 , helps keep those cables very easy to use .pete 1 1 Share this post Link to post Share on other sites
WHX?? 57,904 #57 Posted May 18, 2021 18 minutes ago, peter lena said: @WHX24 use the silicone SUPER LUBE , for lubricant , rated at -40 , helps keep those cables very easy to use .pete Don't know if you know this Pete but you are the official Red Square lubrication guru. We catch anybody using drain oil for anything other than starting brush piles up we are gonna cuff him and stuff him and hand him over to you. Keep up the good work. 2 1 2 Share this post Link to post Share on other sites
Handy Don 17,382 #58 Posted May 19, 2021 2 hours ago, peter lena said: @WHX24, agree with your clamping , added a number of cable clamps to all my cables , and use the silicone SUPER LUBE , for lubricant , rated at -40 , helps keep those cables very easy to use .pete 1 hour ago, WHX24 said: Pete ... you are the official Red Square lubrication guru Might as well ask now. What is your time-tested (and maybe before now secret) method for rejuvenating rusted wound-wire throttle and choke cables? 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,279 #59 Posted May 19, 2021 3 hours ago, WHX24 said: Throttle cable should be clamped to this arm. That arm can be moved by loosening the brass nut behind guv arm. That's what sets the max rpm. Check that the spring loop is in the slot of the plate with the holes in it. The other holes are for fine tweaking. 3 hours ago, WHX24 said: 7 HP but same difference I see what you are saying, but when I tighten the arm with the brass nut it prevents the throttle plate (with holes in it) from turning… Also not sure what you’re referring to when you say the spring loop needs to be in the slot of the hole plate…? Appreciate the guidance… Share this post Link to post Share on other sites
peter lena 10,030 #60 Posted May 19, 2021 @Handy Don, hello don , my standard go to for cable rejuvenation , is to never let it go dry in the first place. once you regularly aerosol spray any rusted area , you are feeding the metal what it needs. typically , remove cable hang vertically , start top lube flow , watch for bottom drip to start , attempt movement , once it starts moving , note , rust drip, repeat this cycle. I also add additional cable clamps , so the cable does not flop around in place , available at local h/w store , small pull out drawer section. that super lube is made for this , another thing I do is to add small extension springs , at the end mount point , so there is a constant balance pull point on the cable , my cables are very smooth and work without effort, take the time to look at how its saposed to work , then enhance it to make it better . when I came in at 2 am for a maintenance failure , you can bet that I also made modifications so that problem was gone , good luck , pete 1 2 Share this post Link to post Share on other sites
WHX?? 57,904 #61 Posted May 19, 2021 The plate with the holes should be free to rotate around a boss on the brass nut. The arm that the cable attaches to should be pinched UNDER that boss so it can't move. you may have to remove the guv arm to verify all this is correct. The spring thingy dealy bob with the hook should be in that bent slotted thingy on the plate with the holes. The other end of the spring should be hooked on the guv arm. You should be able to if that is correct with having to take the arm off. You take the arm off you will need to reset it per the manual. Capiche?!? 1 Share this post Link to post Share on other sites
WHX?? 57,904 #62 Posted May 19, 2021 (edited) Not sure what that drive pin #21 is for never really noticed it on any of mine?? I can see it in your pic. Edited May 19, 2021 by WHX24 Share this post Link to post Share on other sites
peter lena 10,030 #63 Posted May 19, 2021 @WHX24, think I am looking at your cure to the " throw " to the speed control disc, your cable mount is on the OUTER SIDE of your last cable support giving it more strength and drive to move the stetting , think that is worth a try , by @ SLYVANLAKEWH . your close to vertical cable throw does not start the speed disc movement, more of a side thrust will get it going easier, pete 1 Share this post Link to post Share on other sites
peter lena 10,030 #64 Posted May 19, 2021 @SylvanLakeWH, think I would try to get the most out of a cable thrust or drive , your vertical position , it pushing UP , NOT TO THE SIDE , TO TURN THE DISC , think experimenting with that movement and added lubrication , will let you find your spot, pete 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,279 #65 Posted May 19, 2021 Well she “works”… Many thanks to @WHX24 and @peter lena for the help and guidance!!! Took her around the hood tonight and she runs great!!! Looks kinda good in the cleaned up garage… but… doesn’t seem to be any room for the better half’s car… hhhmmm… Fun project!!! 4 4 Share this post Link to post Share on other sites
rjg854 13,330 #66 Posted May 19, 2021 Cars are built to withstand what Mother Nature dish's out. Food for thought 2 1 Share this post Link to post Share on other sites
WHX?? 57,904 #67 Posted May 19, 2021 (edited) This is true Randy but Silvia's noggin can not withstand what SWMBO's frying pan dishes out..... Edited May 19, 2021 by WHX24 3 Share this post Link to post Share on other sites
rjg854 13,330 #68 Posted May 19, 2021 Then a horse barn is a must. SWMBO can have the whole garage, that way 1 Share this post Link to post Share on other sites
peter lena 10,030 #69 Posted May 20, 2021 @SylvanLakeWH , glad it turned out for you ! thanks for the feed back, , your horses and set up looks good , just ask , pete 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,279 #70 Posted May 21, 2021 Hub caps… Red, of course… Details…details…details… 1 3 Share this post Link to post Share on other sites
WHX?? 57,904 #71 Posted May 21, 2021 Fender pan looks real sharp Sylvia, Hard to believe that's an orginal. 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,279 #72 Posted May 21, 2021 5 hours ago, WHX24 said: Fender pan looks real sharp Sylvia, Hard to believe that's an orginal. It’s definitely a “quilt”… looks good on the top but oh boy is the back a mess… fiberglass, resin, some bolts, braces and more resin… Share this post Link to post Share on other sites
WHX?? 57,904 #73 Posted May 21, 2021 Whoops... let's not show our backsides then shall we?!?! 3 Share this post Link to post Share on other sites
SylvanLakeWH 32,279 #74 Posted May 27, 2021 ERGH,,, Went for a quick ride on the newly restored C 85 tonight and... She puked oil from behind the cover and died... Small stream of oil mid-way up... ... Me thinks I will be pursuing my dream of an electric rebuild or, HF, or does someone still rebuild these puppies and sell them on here? I recall seeing someone's ad...? Not gonna look right now... Sun's out and I don't wanna ruin a beautiful evening... JUST... SO... FRUSTRATING... 1 Share this post Link to post Share on other sites
pfrederi 21,095 #75 Posted May 27, 2021 What cover..The valve cover?? Share this post Link to post Share on other sites
