Gregor 4,848 #1 Posted April 25, 2021 My 656 isn't the biggest, or prettiest, or most powerful tractor I have, but I'm not sure it isn't the most fun to drive. That little Tecky sounds awesome with the Kemp stack on it. I decided to do a re-paint on it, before I tear into the C-125 A. It's not going anywhere. I think the previous owner of the 656, took the seat, wheels and tires off, and simply sprayed everything that was left, with red primer. I don't know if he did this to cover up rust, or to keep it from rusting more, but I think once I get started on it, I will find a LOT of rust. This is not going to be a total tear down and strip, but rather a quick spray the best I can do, with it mostly being whole. This is also not going to be your typical Wheel Horse colors. I have something else in mind. It won't be anything crazy, like Arcticat Purple, or Fighting Illini colors, or rainbow. No flames shooting up the side, but it won't be red either. I think it will look nice. I have Terry conjuring up some custom decals. We'll just have to see how it goes. 1 2 1 Share this post Link to post Share on other sites
WheelHorse520H 710 #2 Posted April 25, 2021 That’s a good machine you got there. The white rims are a good accent. Not going red though, this should be interesting. 1 Share this post Link to post Share on other sites
stevasaurus 23,748 #3 Posted April 25, 2021 Gregor, you are scaring me. I think that horse looks great the way it is. Most of the craziness come from those guys in Minnesota and Wisconsin and Connecticut. Have you been eating a lot of cheese and sausage lately?? I know what you mean about the short frame square hoods, I have 2. I'm sure, if Terry is involved, it is going to look great. 2 1 Share this post Link to post Share on other sites
squonk 47,423 #4 Posted April 25, 2021 I agree with @stevasaurus I think it looks cool in primer too. You can replace all the bolts with shiny ones and have a Wisconsiny rebuild! 1 Share this post Link to post Share on other sites
Gregor 4,848 #5 Posted April 25, 2021 (edited) 1 hour ago, stevasaurus said: I think that horse looks great the way it is. I like the way it looks also. Kind-of gotten use to it, but I thought I would try something different. Haven't seen another one done this way, so maybe it's not such a good idea after all. We'll just have to wait and see. P.S. Obviously it was suppose to say "The 656 Project". I don't know how to fix that. Edited April 25, 2021 by stevasaurus Got ya covered. edited by stevaaurus 2 Share this post Link to post Share on other sites
Sparky-(Admin) 25,948 #7 Posted April 25, 2021 2 hours ago, stevasaurus said: Most of the craziness come from those guys in Minnesota and Wisconsin and Connecticut. Ummm....what! Haha....Connecticut guy here 3 Share this post Link to post Share on other sites
Gregor 4,848 #8 Posted April 25, 2021 OK So I went a l i t t l e farther than I had planed. Once you get started, it's just so easy to keep going. 2 1 2 Share this post Link to post Share on other sites
WheelHorse520H 710 #9 Posted April 25, 2021 That didn’t take long. I am interested to see what color you are going to make it. As I said earlier this will be interesting. I see you got the engine out does it run? Share this post Link to post Share on other sites
Gregor 4,848 #10 Posted April 25, 2021 32 minutes ago, WheelHorse520H said: I see you got the engine out does it run? Yes it does. It runs great. But then it should! 1 1 Share this post Link to post Share on other sites
ebinmaine 79,740 #11 Posted April 25, 2021 I'll just be over here in Maine acting perfectly completely fine and normal while watching the next not-red horse come to light. Share this post Link to post Share on other sites
Gregor 4,848 #12 Posted April 26, 2021 I have 1 stuck hub, that's completely dry, and a stuck hitch pin in the trans. They are staying stuck! Not going through that again. Did you know, if you turn the trans upside down, and go in the house for a minute, all the oil will run out the shifter hole. Yep, it will ! 1 3 Share this post Link to post Share on other sites
WheelHorse520H 710 #13 Posted April 26, 2021 41 minutes ago, Gregor said: Did you know, if you turn the trans upside down, and go in the house for a minute, all the oil will run out the shifter hole. Yep, it will ! Glad I don’t have to learn that the hard way, thanks for the tip! Hope you didn’t loose too much. 1 Share this post Link to post Share on other sites
ebinmaine 79,740 #14 Posted April 26, 2021 8 hours ago, Gregor said: I have 1 stuck hub, that's completely dry, and a stuck hitch pin in the trans. They are staying stuck! Not going through that again. Did you know, if you turn the trans upside down, and go in the house for a minute, all the oil will run out the shifter hole. Yep, it will ! Gravity. Gets ya every time... 2 Share this post Link to post Share on other sites
Retired Wrencher 6,793 #15 Posted April 26, 2021 14 hours ago, Gregor said: Yes it does. It runs great. But then it should! If you never had a teckey before they can be a bit finicky. You will find out when it get hot. I hope you enjoy it after it is done. 4 Share this post Link to post Share on other sites
Gregor 4,848 #16 Posted April 26, 2021 Monday Apr. 26, 9 AM. 9 pieces off to the media blaster. How long? How much? 3 1 Share this post Link to post Share on other sites
Pullstart 70,770 #17 Posted April 26, 2021 Likely all you’ve had blasted, an e-tank setup could have been built quicker and cheaper ... 1 Share this post Link to post Share on other sites
Gregor 4,848 #18 Posted April 26, 2021 4 hours ago, pullstart said: an e-tank setup could have been built quicker and cheaper I may have to try that sometime, but it would be something else I would have to find a space for. Submerging some parts, may not always be so great. I had these wheels chemically stripped weeks ago, and they are still seeping some kind of fluid out from the inside. 1 Share this post Link to post Share on other sites
Pullstart 70,770 #19 Posted April 26, 2021 5 minutes ago, Gregor said: I may have to try that sometime, but it would be something else I would have to find a space for. Submerging some parts, may not always be so great. I had these wheels chemically stripped weeks ago, and they are still seeping some kind of fluid out from the inside. the only chemical if you will, is washing soda with the e-tank. I understand the space constraint, just move the dishwasher out on the deck to free up to little more room 1 Share this post Link to post Share on other sites
Gregor 4,848 #20 Posted April 27, 2021 The Tecky from the 656 got a face lift today. I just didn't think the red would go well with the new color scheme I have planned for the tractor. 3 1 Share this post Link to post Share on other sites
WheelHorse520H 710 #21 Posted April 27, 2021 3 hours ago, Gregor said: The Tecky from the 656 got a face lift today. I just didn't think the red would go well with the new color scheme I have planned for the tractor. Black with chrome exhaust you must have some color scheme planned out. Can’t wait to see that thing when it’s done. Share this post Link to post Share on other sites
Gregor 4,848 #22 Posted April 28, 2021 The color scheme is not going to be anything crazy, but, you do know I also restore Lawn Boy mowers right? Naaaaah.. It aint gonna be green. That would probably get me kicked off of 1 Share this post Link to post Share on other sites
rjg854 13,200 #23 Posted April 28, 2021 Hope I don't step on anyone's toes with this statement, but, I like to break all the red on these tractors a bit. I think a black engine is that little bit of difference. 1 Share this post Link to post Share on other sites
ebinmaine 79,740 #24 Posted April 28, 2021 1 minute ago, rjg854 said: Hope I don't step on anyone's toes with this statement, but, I like to break all the red on these tractors a bit. I think a black engine is that little bit of difference. Wholeheartedly agreed. Note that the engines Trina and I have painted are not red... 1 Share this post Link to post Share on other sites
Gregor 4,848 #25 Posted April 29, 2021 On 4/26/2021 at 7:57 AM, Gregor said: Monday Apr. 26, 9 AM. 9 pieces off to the media blaster. How long? How much? Thursday Apr. 29. That was record time ! I added a couple of pieces so it was 11. $140. I am not a body and fender man, but I am going to attempt a little bondo work on the fender pan, and dash tower. The pieces come back perfectly clean, and ready for paint, after w wipe down with paint thinner. 2 2 Share this post Link to post Share on other sites
