Adamw89 0 #1 Posted April 23, 2021 I have a charger 10 hydromatic wheel horse. I had to pull it back in the garage so i turned the nut ontop of the axel under the seat so it rolled freely. I turned the nut back in now it wont move and wheels remain unlocked Share this post Link to post Share on other sites
Pullstart 66,559 #2 Posted April 23, 2021 Have you checked the fluid level? I know it sounds silly, but might be overlooked. Also, I’ve seen some tow valves work with 90 degrees of movement, but most suggest 180. The roll pin pointing forward if I recall should be full flow. Share this post Link to post Share on other sites
Adamw89 0 #3 Posted April 23, 2021 Yeah i checked the fluid level its full Share this post Link to post Share on other sites
daveoman1966 3,839 #4 Posted April 23, 2021 Was the tractor runnng and moving correctly BEFORE you pulled it back to the garage? This is the push VALVE on top of the Hyd Pump End Cap. Is this what you turned to allow the tractor to roll freely? You would only have to turn the ROLLPIN just 90 degrees to allow free-roll. However, you still need to roll it SLOWLY. ps... These are the only pic of the PUSH valve I have...from a pump refurb of a few years agol. Share this post Link to post Share on other sites
Adamw89 0 #5 Posted April 23, 2021 (edited) Yeah thats it what i turned and yes it worked fine before i loosened it and pulled it back to garage Edited April 23, 2021 by Adamw89 Share this post Link to post Share on other sites
Adamw89 0 #6 Posted April 23, 2021 Another thing is that valve the top part is missing with the pin. Its just a flat bolt i loosend it with a 1inch socket Share this post Link to post Share on other sites
squonk 43,698 #7 Posted April 23, 2021 1 inch socket sounds too big. I think you moved the wrong thing! Share this post Link to post Share on other sites
953 nut 59,716 #8 Posted April 23, 2021 11 hours ago, Adamw89 said: I had to pull it back in the garage so i turned the nut ontop of the axel under the seat so it rolled freely. Was the tractor operating properly going forward but wouldn't go in reverse? Here is a manual that should be helpful. Share this post Link to post Share on other sites
Ed Kennell 41,765 #9 Posted April 23, 2021 7 hours ago, Adamw89 said: top part is missing with the pin. Looks like you need a new valve. Post a picture of your valve. 1 Share this post Link to post Share on other sites
