ashtonosborne2019 18 #1 Posted April 13, 2021 today my wh 520-h would drive up the drive way like 20 ft and just shut off and not start it will idle but when i drive it for a bit it shuts off maybe spark plug coil or starter solenoid or ignition switch. Share this post Link to post Share on other sites
Achto 30,488 #2 Posted April 13, 2021 Could also be your gas cap vent. Share this post Link to post Share on other sites
lynnmor 8,384 #3 Posted April 13, 2021 Bad fuel pump or the screen in the tank outlet is clogged. Just a guess, give additional performance history and maybe we can narrow it down. Share this post Link to post Share on other sites
ashtonosborne2019 18 #4 Posted April 13, 2021 8 hours ago, Achto said: Could also be your gas cap vent. i don't remember if there is a vent on the cap or not 1 Share this post Link to post Share on other sites
ashtonosborne2019 18 #5 Posted April 13, 2021 7 hours ago, lynnmor said: Bad fuel pump or the screen in the tank outlet is clogged. Just a guess, give additional performance history and maybe we can narrow it down. i switched the pump yesterday and the tank outlet might be clogged. the tractor has great performance history and it will only get 1 spark every half a minute and that is what leads me to think why the spark plug coil or the stator. Share this post Link to post Share on other sites
Achto 30,488 #6 Posted April 13, 2021 27 minutes ago, ashtonosborne2019 said: i don't remember if there is a vent on the cap or not The cap should have a vent.of some sort. 23 minutes ago, ashtonosborne2019 said: it will only get 1 spark every half a minute and that is what leads me to think why the spark plug coil or the stator. I had a similar issue with my 520, mine turned out to be a corroded fuse block. The fuse for the ignition would loose contact momentarily. Diagnosed this when I noticed some of the gauges cutting out at the same time I lost spark. Share this post Link to post Share on other sites
ashtonosborne2019 18 #7 Posted April 13, 2021 Just now, Achto said: The cap should have a vent.of some sort. I had a similar issue with my 520, mine turned out to be a corroded fuse block. The fuse for the ignition would loose contact momentarily. Diagnosed this when I noticed some of the gauges cutting out at the same time I lost spark. i will run it tomorrow and see if it has the gauge problem 1 Share this post Link to post Share on other sites
ashtonosborne2019 18 #8 Posted April 14, 2021 14 hours ago, ashtonosborne2019 said: i will run it tomorrow and see if it has the gauge problem ya it was that but i want to put a bunch of other parts on to so now is a good time thanks for the shooters Share this post Link to post Share on other sites
