TractorChild97 158 #1 Posted April 11, 2021 I have split open an 8 speed out of an old tractor I got recently. I split it open and checked the needles bearings and cleaned up the gears. I absolutely cannot get this trans put back together. Iv split other 8 speeds in the past and never had this hard of a time. Any advice would be super appreciated! Share this post Link to post Share on other sites
ranger 1,854 #2 Posted April 11, 2021 Not having taken one of these apart before, I can only wonder if perhaps a needle from one of the bearings has come adrift and is jammed between the end of a shaft and the bearing cap? I don’t know. This is something I have come across before with auto driveshaft universal joints. However, I’m sure someone on here will have the answer for you. 3 Share this post Link to post Share on other sites
953 nut 67,302 #3 Posted April 11, 2021 I have foumd that alternately rotating the input shaft and brake drum while tapping the case with a rubber mallet works to get it to come together. 2 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #4 Posted April 11, 2021 1 hour ago, ranger said: Not having taken one of these apart before, I can only wonder if perhaps a needle from one of the bearings has come adrift and is jammed between the end of a shaft and the bearing cap? I don’t know. This is something I have come across before with auto driveshaft universal joints. However, I’m sure someone on here will have the answer for you. Got the same problem 2days ago. the axles weren't cleaned up enhough. Further tips, make sure everything is aligned nicely. inspect that everything is sitting in deep enough in the right-side casing before putting the left-side on. 1 1 Share this post Link to post Share on other sites
Pullstart 70,513 #5 Posted April 11, 2021 I am just throwing this out there... It seems the diff bolts should be pointed in a certain direction in @stevasaurus’ videos... maybe that is the hood up? 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,331 #6 Posted April 11, 2021 Do I recall a gear being put in backwards can cause this? Garry 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #7 Posted April 11, 2021 3 hours ago, pullstart said: I am just throwing this out there... It seems the diff bolts should be pointed in a certain direction in @stevasaurus’ videos... maybe that is the hood up? Absolutely! they only go in whit the nut away from the gear, that side is a hair longer, and sometimes it just hits enough to be allow the tranny to be closed but will do damage to the bull gear. 2 hours ago, gwest_ca said: Do I recall a gear being put in backwards can cause this? no sure on this tho Share this post Link to post Share on other sites
stevasaurus 23,739 #8 Posted April 11, 2021 Things to look for... 1. Are the reduction and pinion gears even on the cluster gear and input shaft?? 2. Did you add any shims to the input shaft or under the 11/44 toothed gear?? 3. Is there any debris around or in the holes or studs that align the case halves?? 4. The nuts on the differential should be facing up, except for the 10 pinion LS differentials. (which face down) 5. Check to see if all of your inside bearings are flush with the inside of the case half. 6. Sometimes, using the 4 corner bolts to evenly and delicately force the case halves to close. (last resort) 7. Is it 1/8" all the way around?? Reduction and pinion gears are even. 3 1 Share this post Link to post Share on other sites
TractorChild97 158 #9 Posted April 11, 2021 😲 thanks for the list @stevasaurus gonna go check that out tonight! 1 Share this post Link to post Share on other sites
TractorChild97 158 #10 Posted April 12, 2021 @stevasaurus I had my diff bolts the tap side down. I flipped the bolts and Boom! Went together slicker than pulling a greasy string out of a cats hind end. Thanks again guys! 1 1 Share this post Link to post Share on other sites
rmaynard 17,416 #11 Posted April 12, 2021 1 hour ago, TractorChild97 said: Went together slicker than pulling a greasy string out of a cats hind end. 1 Share this post Link to post Share on other sites
TractorChild97 158 #13 Posted April 13, 2021 This set screw broke off. Looks like a drill rethreading coming soon. Share this post Link to post Share on other sites
stevasaurus 23,739 #14 Posted April 13, 2021 If you can grab that with something, it may turn right out...they are not usually that tight in there. If that is a regular dog point set screw, it is hardened steel. It doesn't drill easily. 1 Share this post Link to post Share on other sites
TractorChild97 158 #15 Posted April 14, 2021 Got it!! 1 Share this post Link to post Share on other sites
TractorChild97 158 #16 Posted April 14, 2021 @stevasaurus Needle nose pliers got it right out 1 Share this post Link to post Share on other sites
