krystolo 504 #26 Posted April 7, 2021 1 hour ago, 953 nut said: The voltage fluctuates in the spark plug wire cap when I turn to start. With the spark plug connected to the plug wire and laying on the cylinder head is there a spark that will jump toe >035" gap? No just not turning over (starting) After attempting to start the engine is the tip of the spark plug wet with fuel? No, but haven't checked it immediately after trying to start it. thoughts? Did this problem exist before the carburetor rebuild? Yes 1 Share this post Link to post Share on other sites
squonk 47,745 #27 Posted April 7, 2021 Get a spark tester before doing anything else. I repeat: laying a plug on a head and checking for spark really doesn't work well all the time. Corroded aluminum head fins are a poor ground. Get a spark tester. 1 Share this post Link to post Share on other sites
krystolo 504 #28 Posted April 7, 2021 (edited) Got the spark plug tester. No flashing light. 😞 With the continuity tester, I have light at condenser positive and negative, neg flashes when turned to start. light at point screw bad spark plug wire? Edited April 7, 2021 by krystolo 1 Share this post Link to post Share on other sites
krystolo 504 #29 Posted April 7, 2021 There is enough power inside the spark plug cap thing to light the continuity tester, but not the spark plug tester. could this be a coil problem? Share this post Link to post Share on other sites
Achto 32,254 #30 Posted April 7, 2021 5 minutes ago, krystolo said: could this be a coil problem? You had mentioned that the coil had gotten hot. There is a possibility that the coil is damaged. You can get a new coil from Tractor Supply Co. It is very important that you get a 12v coil with an internal resistor. Napa would also be a good source for a coil. 2 Share this post Link to post Share on other sites
krystolo 504 #31 Posted April 7, 2021 5 minutes ago, Achto said: You had mentioned that the coil had gotten hot. There is a possibility that the coil is damaged. You can get a new coil from Tractor Supply Co. It is very important that you get a 12v coil with an internal resistor. Napa would also be a good source for a coil. I know I have left it on run several times. Like for hours. Headed to Napa! 1 Share this post Link to post Share on other sites
krystolo 504 #32 Posted April 7, 2021 The folks at Napa are really getting to know me. Lol 2 Share this post Link to post Share on other sites
305 381 #33 Posted April 7, 2021 i work at an auto parts store partime and when someone needs a coil for Kohler points ignition engine i get them Primeline part # 7-01634 that's the number that Napa would use , but as said any coil as long as it's 12 volts and internally resisted should be fine 1 Share this post Link to post Share on other sites
krystolo 504 #34 Posted April 7, 2021 4 hours ago, 305 said: i work at an auto parts store partime and when someone needs a coil for Kohler points ignition engine i get them Primeline part # 7-01634 that's the number that Napa would use , but as said any coil as long as it's 12 volts and internally resisted should be fine Got it! Share this post Link to post Share on other sites
squonk 47,745 #35 Posted April 7, 2021 (edited) Napa IC14 too. Already mentioned it yesterday. POST #15 Also cheaper than the Primeline one. Edited April 7, 2021 by squonk 1 Share this post Link to post Share on other sites
krystolo 504 #36 Posted April 7, 2021 YES!!! IMG_1598.MOV 1 4 Share this post Link to post Share on other sites
ebinmaine 80,087 #38 Posted April 7, 2021 9 minutes ago, krystolo said: YES!!! AWESOME!!! Share this post Link to post Share on other sites
ebinmaine 80,087 #39 Posted April 7, 2021 Just now, squonk said: Nothing like a dancing banana to demonstrate one's excitement. 1 1 Share this post Link to post Share on other sites
krystolo 504 #40 Posted April 7, 2021 I think I over WD40’d my throttle cable and it slips a little. Whoops! Share this post Link to post Share on other sites
squonk 47,745 #41 Posted April 7, 2021 Just now, ebinmaine said: Nothing like a dancing banana to demonstrate one's excitement. 3 Share this post Link to post Share on other sites
rjg854 13,269 #42 Posted April 7, 2021 44 minutes ago, krystolo said: YES!!! IMG_1598.MOV Share this post Link to post Share on other sites
krystolo 504 #43 Posted April 7, 2021 A BIG thank you to everyone who helped me with this. I learned so much! 4 Share this post Link to post Share on other sites
ebinmaine 80,087 #44 Posted April 7, 2021 5 minutes ago, krystolo said: learned so much THAT'S the thing that counts.... 1 Share this post Link to post Share on other sites
Achto 32,254 #45 Posted April 7, 2021 (edited) SO AWESOME!!! I glad that you have it running. Edited April 7, 2021 by Achto 1 Share this post Link to post Share on other sites
lynnmor 8,970 #46 Posted April 7, 2021 (edited) 9 hours ago, krystolo said: I think I over WD40’d my throttle cable and it slips a little. Whoops! I hate when that happens. Cannot see your cable from here but to regain some friction, spray parts cleaner at the dash end mechanism several times. Work the cable while spraying. I prefer the chlorinated type for the best cleaning. Edited April 8, 2021 by lynnmor 3 Share this post Link to post Share on other sites
krystolo 504 #47 Posted April 9, 2021 @lynnmor worked like a charm! Thanks for the tip. Share this post Link to post Share on other sites
