krystolo 504 #1 Posted April 4, 2021 The black gasket was hanging out of the carb, so I too the bowl off. Is it supposed to be two pieces? Advice on getting it back together? 1 Share this post Link to post Share on other sites
krystolo 504 #2 Posted April 4, 2021 Seems like the bowl gasket is stretched out. It’s a little too big. 1 Share this post Link to post Share on other sites
8ntruck 8,153 #3 Posted April 4, 2021 This is off of a Kohler engine, right? These engines typically have a gasket that fits in a groove in the upper part of the carb and the flat gasket that fits on top of the bowl and under the gasket in the groove. The flat gasket usually hangs outside the carb a little bit. The flat gasket on my tractor has a cut out that fits around the float pivot point. Didn't notice that notch in yours. 1 Share this post Link to post Share on other sites
953 nut 62,174 #4 Posted April 4, 2021 You can buy a carb. rebuild kit at most good auto parts stores or for about $ 10.00. 1 Share this post Link to post Share on other sites
JoeM 8,899 #5 Posted April 4, 2021 53 minutes ago, krystolo said: Advice on getting it back together? much easier to get together with the carb off and turned upside down. 2 1 Share this post Link to post Share on other sites
pacer 3,177 #6 Posted April 4, 2021 2 minutes ago, JoeM said: much easier to get together with the carb off and turned upside down. Most definitely!! Have the carb off and on the bench upside down, getting those 2 gaskets seated right can be finiky. On the flat thin gasket that wide area is there to help against fuel from 'sloshing' around and getting into the intake 3 Share this post Link to post Share on other sites
richmondred01 2,311 #7 Posted April 4, 2021 1 hour ago, krystolo said: The black gasket was hanging out of the carb, so I too the bowl off. Is it supposed to be two pieces? Advice on getting it back together? you need a new kit. kohler 2575701S 2 Share this post Link to post Share on other sites
Bill D 2,363 #8 Posted April 4, 2021 I also change the float bowl when rebuilding a carb. I use Briggs PN 221995. It's made of plated steel and is more resistant to corrosion. Bill 4 Share this post Link to post Share on other sites
krystolo 504 #9 Posted April 4, 2021 1 hour ago, 8ntruck said: This is off of a Kohler engine, right? These engines typically have a gasket that fits in a groove in the upper part of the carb and the flat gasket that fits on top of the bowl and under the gasket in the groove. The flat gasket usually hangs outside the carb a little bit. The flat gasket on my tractor has a cut out that fits around the float pivot point. Didn't notice that notch in yours. It has two little notches. Share this post Link to post Share on other sites
krystolo 504 #10 Posted April 4, 2021 18 minutes ago, richmondred01 said: you need a new kit. kohler 2575701S Is that because the bowl gasket is stretched? Share this post Link to post Share on other sites
richmondred01 2,311 #11 Posted April 4, 2021 Stretched and most likely hard and brittle. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,740 #12 Posted April 4, 2021 12 minutes ago, krystolo said: Is that because the bowl gasket is stretched? I think it is more the fuel causes them to swell and all makes do it. Guess that is better than shrinking. Garry Share this post Link to post Share on other sites
953 nut 62,174 #13 Posted April 5, 2021 These carburetors are not at all difficult to rebuild. Look over this thread and you will see what needs to be done. 1 Share this post Link to post Share on other sites
krystolo 504 #14 Posted April 5, 2021 @953 nut Thank you! Share this post Link to post Share on other sites
krystolo 504 #15 Posted April 5, 2021 @953 nut How do I know if it needs to be completely rebuilt vs just new gaskets? Thanks! Share this post Link to post Share on other sites
rjg854 12,515 #16 Posted April 5, 2021 While you have it off, might as well do a through cleaning. That way you might not have to go pull the carb again. 1 Share this post Link to post Share on other sites
