ebinmaine 63,335 #351 Posted January 23 Also got the no start condition assessed and repaired. Spark plug. Trina made and installed new super wicked heavy duty Heim Joint tie rods. She drilled out all four holes to 29/64 to accommodate the 7/16 studs. She also made up this super wicked incredible high tech oil director tool. 1 2 2 Share this post Link to post Share on other sites
Handy Don 10,659 #352 Posted January 23 McTrinaguyver? 1 Share this post Link to post Share on other sites
ebinmaine 63,335 #353 Posted January 23 1 hour ago, Handy Don said: McTrinaguyver? More than you could possibly know 2 Share this post Link to post Share on other sites
ebinmaine 63,335 #354 Posted January 25 On 11/26/2023 at 8:11 AM, 953 nut said: You can check the battery voltage at rest and while running at half throttle. If there is an increase in voltage your charging system is good to go. It has been some time since you were doing the wiring so I don't remember if you used a solenoid or what light socket you used. The generator light should have two wires coming from it and neither one will be grounded, the Cole-Hersee PL 20 RC is the correct socket. If you used a solenoid and 103-990 ignition switch with a Starter/Generator the drawing below is the one you want to follow. I gave this post the once-over, twice. Then compared to the tractor. (Unfortunately??) It looks correct. .....but that 🤬 lamp is constant on. So I obviously have more diagnostics to do. If anyone has bench tests or places to look I'm all ears. 1 Share this post Link to post Share on other sites
ebinmaine 63,335 #355 Posted January 25 I did get the proper ish engine oil drain pipe on. It exits the opposite side from normal but I'm limited to space here. If it doesn't clear the plow control I'll modify as needed. 1 2 Share this post Link to post Share on other sites
Handy Don 10,659 #356 Posted January 25 27 minutes ago, ebinmaine said: I gave this post the once-over, twice. Then compared to the tractor. (Unfortunately??) It looks correct. .....but that 🤬 lamp is constant on. Not familiar with this setup but very curious. I’m assuming the lamp is intended to replace the ammeter and, again assuming, it should be lit whenever the S/G is not charging? 1 Share this post Link to post Share on other sites
ebinmaine 63,335 #357 Posted January 25 5 minutes ago, Handy Don said: Not familiar with this setup but very curious. I’m assuming the lamp is intended to replace the ammeter and, again assuming, it should be lit whenever the S/G is not charging? That's logical Share this post Link to post Share on other sites
Lee1977 6,259 #358 Posted January 25 Just a quick guess the, the wrong key switch or a bad key switch. The switch doesn't show what is on and what is grounded when off. The only time I had trouble with a generator light was when I changed a 292 with a generator to a 302 with an alternator. Fire it up and the generator light would come on, rev it up the light would go off and everything was fine. If electricity is giving a path, it will back feed. At a neighbor's house, the old 220 electric range had two screw in fuses up on the back between the controls. The ceiling light in the kitchen came on with the switch off if the range was turned on. I found one of the fuses blown causing the back feed. 1 1 2 Share this post Link to post Share on other sites
ebinmaine 63,335 #359 Posted January 31 We got the old girl out and plow hooked up the other day. Millie tractor was running fine. Trina started to move snow and got one pass before the engine made a noise and stopped. I'm hoping it has a sheared flywheel key. 2 Share this post Link to post Share on other sites
ebinmaine 63,335 #360 Posted April 7 On 1/31/2024 at 12:00 PM, ebinmaine said: We got the old girl out and plow hooked up the other day. Millie tractor was running fine. Trina started to move snow and got one pass before the engine made a noise and stopped. I'm hoping it has a sheared flywheel key. Several weeks ago we took a quick look at the engine. With of us were thinking and hoping that the flywheel key was the culprit. This morning Trina removed whatever was needed to get the flywheel off. We have the rare but undesirable two piece flywheel key. While in there I noticed that the 4 bolts holding the engine half around the crankshaft were loose. 2 were leaking. We found some new Grade 8 bolts, installed them, and torqued to spec. We'll pop in a crankshaft seal on that end before reassembly. 3 Share this post Link to post Share on other sites
ebinmaine 63,335 #361 Posted April 8 This should look familiar. Do you know what this is? It might look like shrink wrap on a roll but in reality that is not true. This is a small block Kohler crankshaft seal driver. Got the flywheel cleaned out. It wasn't bad. Just a little dusty really. Hand wire brushed the threads. Oiled them too. Installed the nut and torqued it to 90 ft lbs. 3 Share this post Link to post Share on other sites
Tractorhead 8,612 #362 Posted April 8 Great to hear it was just the flywheel key. it shouldbe happen, that you take a closer look on the loosen screws. That confirms my Statement once more: „nothing is for less, it allway’s have its reason.“ 👍 1 Share this post Link to post Share on other sites
ebinmaine 63,335 #363 Posted April 17 The other day we were looking at a but of oil on the 3rd and 4th fin down from the cylinder head. We believe after poking around and wiping some areas down that the head gasket may have been losing a little out the S/G side. We removed the head, cleaned more, checked for more issues, and reinstalled the head. Torqued down to 20+ ft lbs. Well see how it goes. This afternoon Trina got everything all back together. We gave it a quick triple check and fired Millie up. Seems OK so far. Share this post Link to post Share on other sites
