DANELMER 2 #26 Posted April 11, 2021 @Brockport Bill hey thanks for the tips! I can't figure out how to keep the bagger attached to the deck. Also how do you clean your deck? Thanks! Share this post Link to post Share on other sites
Brockport Bill 1,951 #27 Posted April 11, 2021 there's a horseshoe piece you may not have that slides down over the "nub" of tube and clips over the end of the tube onto the front edge end of the deck - it might be shown online somewhere for the bagger unit - i'll get photo later to post. To clean under deck i just lean down and reach under the deck with putty knife and scrape bad heavy clumps off - then every couple mowings since its so easy to remove the deck i slide it out and do a full putty knife scraping - then every couple more mowings I do pressure wash and clean it down bare -- its in the spring when grass is sticky like super glue that it really sticks to deck - but as mentioned by others on the forum -- use lubricant to spray under clean deck with wd-40 or other type product - or a silicone spray -- that really reduces grass sticking -- there are also commercial products that claim to do that. 1 Share this post Link to post Share on other sites
Brockport Bill 1,951 #28 Posted April 11, 2021 DANELMER -- the mower should be 05-37SC01 that's zero five, thirty seven, letter S , letter C then zero one.................... the bagger manual is 810608R1 - it came up obsolete but might be here on the forum resources????/ The bagger number on mine is model 0711BC01 1 Share this post Link to post Share on other sites
Brockport Bill 1,951 #29 Posted April 11, 2021 here are the photos i took ..... just a reminder you need a "lift blade" for the bagger.. also showed the latches you asked about ....where the clip attaches to deck -- it just slides over the tube nub and onto roller arm bracket 1 Share this post Link to post Share on other sites
Brockport Bill 1,951 #30 Posted April 11, 2021 the bagger model shows up on Parts Tree and EReplacementparts,com etc Share this post Link to post Share on other sites
DANELMER 2 #31 Posted April 13, 2021 Thanks everyone! I used a c clamp for not to keep the bagger on. Had my first mow today and everything seemed to work fine. I think I may need to sharpen my blades and there is a high pitched squeal coming from the mower whenever I turn it on. Other than that all is well! Thanks again! Share this post Link to post Share on other sites
Brockport Bill 1,951 #32 Posted April 13, 2021 i use a leaf blower to blow away the debris on top of mower deck - keeps debris from pulley and belt area -- and if the deck gets wet the wet debris won't rot the deck -- also use blower to clean the bags as well as the breather screen inside the hood flap -- did you check to see if the blades are the "lift' design? 1 Share this post Link to post Share on other sites
Brockport Bill 1,951 #33 Posted April 14, 2021 Dan -- here's my near twin to your WH Share this post Link to post Share on other sites
