rmaynard 17,424 #1 Posted March 30, 2021 Looking for a source for a replacement lens for my Kelch gas cap. This is from my 1967 REO lawn skiff with Tecumseh V60 engine. Glen Pettit has larger ones, but this is 1-9/16" in diameter. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,353 #2 Posted March 31, 2021 Wondering if Glen's could be sanded to size on a bench disc or belt sander? Insert it into a bead of Seal-All. If I remember correctly his plastic is not affected by the fuel like others. Garry 1 Share this post Link to post Share on other sites
Pullstart 70,705 #3 Posted March 31, 2021 It seems like people have sourced bottle bottoms or the like for lenses? With the amazing YouTube, I’ve seen people warming a piece of sheet plastic then forming it over a mold of sorts then trimming to fit... 1 Share this post Link to post Share on other sites
rmaynard 17,424 #4 Posted April 13, 2021 Since I did not find exactly what I was looking for, I decided to think outside of the box. Here is what I found. Upon further detailed examination, I determined that the inside diameter of the top of the cap (under the lip) was not 1-9/16". It is 41mm, I found an acrylic, domed, 40.9mm pocket watch lens. All that I need to determine is whether I need to drill a small hole in it to act as a vent. Problem solved. 2 Share this post Link to post Share on other sites
Retired Wrencher 6,785 #5 Posted April 14, 2021 On 3/31/2021 at 9:17 AM, gwest_ca said: Wondering if Glen's could be sanded to size on a bench disc or belt sander? Insert it into a bead of Seal-All. If I remember correctly his plastic is not affected by the fuel like others. Garry Garry that Seal All is good stuff. Hard to find at times, but use it around leaky gas kits. Share this post Link to post Share on other sites
