Lane Ranger 12,031 #1 Posted March 20, 2021 I have two new bearing flanges that should work on my sickle bar mower rebuild but I am looking for a source for these flanges. let me know if you have a source or online company that sells these. Share this post Link to post Share on other sites
squonk 47,384 #2 Posted March 20, 2021 Can you use square holes? https://bearingsdirect.com/ 1 Share this post Link to post Share on other sites
peter lena 9,942 #3 Posted March 20, 2021 LANE, NOTING THE RUBBER SIDE SEALS ON THOSE BEARINGS GIVES YOU THE OPPORTUNITY , TO USE A HI TEMP GREASE IN THEM , AND PREVENT A FAILURE. POCKET SCREWDRIVER AND LUCAS HEAVY DUTY GREASE , OR RED AND TACKY . REPACKED ALL OF MY RUBBER SEAL BEARINGS , NO NOISE AND NO FAILURES , PETE 1 Share this post Link to post Share on other sites
WHX?? 57,392 #4 Posted March 21, 2021 Are they for this shaft? I almost think TSC might have them I know that's where I got the bearings from. 4 Share this post Link to post Share on other sites
Lane Ranger 12,031 #5 Posted March 22, 2021 https://thebigbearingstore.com/3-bolt-round-stamped-housing-52mm-od-bearings/ I found a supplier and the flanges for the sickle frame box are three hole 5/16 square that fit 205 bearings. 52MS lots of suppliers once you have the correct part number! The original Wheel Horse manuals listed the bearing and flanges together with a Wheel Horse bearing number. Share this post Link to post Share on other sites
giddyap 1,574 #6 Posted March 23, 2021 (edited) surpluscenter.com generic Edited March 23, 2021 by giddyap Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,353 #7 Posted March 23, 2021 Those bearing retainers must be different for some applications. I recall the most common available 3/4" bearing for the snowthrowers would not fit. The most common available 7/8" bearing retainers would fit so members were adding a bushing to get the ID down to 3/4". There was a substantial cost saving doing this. Garry 1 Share this post Link to post Share on other sites
WHX?? 57,392 #8 Posted March 23, 2021 3 hours ago, gwest_ca said: adding a bushing to get the ID down to 3/4". Exactly what I did..... 1 Share this post Link to post Share on other sites
Lane Ranger 12,031 #9 Posted March 23, 2021 I did that too on my last rebuild! That was Robert Maynard’s snowblower rebuild info posted when he redid his bearings on one. Share this post Link to post Share on other sites
