clueless 3,427 #1 Posted February 23, 2021 When was the last year the 6 inch front wheels tractor came out? Share this post Link to post Share on other sites
Ed Kennell 46,554 #2 Posted February 23, 2021 My '86 312H had the 6"ers. It has 8" now. No clue on last year. 2 Share this post Link to post Share on other sites
clueless 3,427 #3 Posted February 23, 2021 12 minutes ago, Ed Kennell said: My '86 312H had the 6"ers. It has 8" now. No clue on last year. I think the 6 inch front wheels were started around 1985 for the two blade 37 SD inch deck, just wondering when the last year they were produced? 1 Share this post Link to post Share on other sites
953 nut 67,364 #4 Posted February 23, 2021 Take a look at the pictures in the 2007 thread I attached to your other post. The front spindles are the long ones so 6" wheels were used right up to the end. 3 Share this post Link to post Share on other sites
Racinbob 13,040 #5 Posted February 24, 2021 (edited) 13 hours ago, 953 nut said: Take a look at the pictures in the 2007 thread I attached to your other post. The front spindles are the long ones so 6" wheels were used right up to the end. Actually I believe when they put the 'Classic GT' decal on the side and quit using the '315' is when the 6" wheels went away but I'm kinda guessing. My 2005 came with 8". Edited February 24, 2021 by Racinbob 1 Share this post Link to post Share on other sites
peter lena 9,939 #6 Posted February 24, 2021 never liked the look of the 6" wheel, always changed mine over , to 8" , the side view with the smaller wheel is out of proportion to the frame size . my 82 C -85 had 8" originally, the two other horses I have just did not look right when paired up to the older unit. just my own opinion , have all 3 set up the same way , in all areas , to make things reliable and simple , mixing both older and newer , builds, pete 1 Share this post Link to post Share on other sites
clueless 3,427 #7 Posted February 24, 2021 My thought is when they quit producing the 37 inch side discharge deck is when they stopped using the 6 inch wheels. Share this post Link to post Share on other sites
Racinbob 13,040 #8 Posted February 24, 2021 There's not a lot of information out there for the final years of the Wheel Horse that we all know. It looks to me like the last 5-6 years there wasn't a lick of difference in them. Maybe even dating back to when they started using Command Pro engines which I believe was 98 or 99. Everything I've found lists 16x8.50-8 fronts leading me to believe the 6" fronts were discontinued in the 90's. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,343 #9 Posted February 24, 2021 1990-2001 312-8 used 117285 6" wheel 1999-2001 314-8 used 117285 6" wheel Garry 2 Share this post Link to post Share on other sites
clueless 3,427 #10 Posted February 25, 2021 7 hours ago, gwest_ca said: 1990-2001 312-8 used 117285 6" wheel 1999-2001 314-8 used 117285 6" wheel Garry Thanks Garry, but I have a 1987 and a 1989 312-8, second owner, that both have the 6" wheels. Share this post Link to post Share on other sites
953 nut 67,364 #11 Posted February 25, 2021 Yes, my '87 had 6" front tires also used on my '92. The 8" front tires were used on the larger displacement units like the 417. Share this post Link to post Share on other sites
tom2p 2,394 #12 Posted February 25, 2021 (edited) 6" fronts on the classic 300-400 series garden tractors don't pass the eye test bad decision maybe the 6" fronts could have been offered as a dealer option for use with the 37" deck ... or whatever I rolled a 6" tire off the rim plowing brush / dirt - and then later a 6" front tire developed a large bubble providing the motivation to finally replace the 6" fronts with 8" fronts Edited February 25, 2021 by tom2p Share this post Link to post Share on other sites
953 nut 67,364 #13 Posted February 25, 2021 300 series had the 6" front tires (15-6.00 X 6) and the 400/500 series had the 8" front tires ((16-6.50 X 8). Look at the brochures! Share this post Link to post Share on other sites
Ed Kennell 46,554 #14 Posted February 25, 2021 I replaced the factory 6" wheels on my '86 312H with 8" wheels and kept the longer 6" spindles. This gave me additional clearance under the front axle allowing higher lifting for the snow plow and front tiller. Share this post Link to post Share on other sites
tom2p 2,394 #15 Posted February 25, 2021 2 hours ago, 953 nut said: 300 series had the 6" front tires (15-6.00 X 6) and the 400/500 series had the 8" front tires ((16-6.50 X 8). I've also seen some early 90's 416-H with 6" front tires ( ughhh lol) Share this post Link to post Share on other sites
tom2p 2,394 #16 Posted February 25, 2021 (edited) 2 hours ago, Ed Kennell said: I replaced the factory 6" wheels on my '86 312H with 8" wheels and kept the longer 6" spindles. This gave me additional clearance under the front axle allowing higher lifting for the snow plow and front tiller. I like the front tiller ! I did the same - replaced 6" fronts with 8" fronts on a 312-8 and kept the longer spindles I also have an extra set of short spindles - but prefer the long spindles Edited February 25, 2021 by tom2p 1 Share this post Link to post Share on other sites
RKCrizzle 16 #17 Posted August 15, 2024 where can I get replacement wheels for the front, part number: 117285 trying to replace tires I found my front wheels to be really badly rusted on the inside. Share this post Link to post Share on other sites
953 nut 67,364 #18 Posted August 15, 2024 7 hours ago, RKCrizzle said: where can I get replacement wheels for the front, part number: 117285 trying to replace tires I found my front wheels to be really badly rusted on the inside. Give Lincoln at A-Z Tractor a call. https://www.a-ztractor.com/ 1 Share this post Link to post Share on other sites
clueless 3,427 #19 Posted August 17, 2024 On 8/15/2024 at 6:37 PM, 953 nut said: Give Lincoln at A-Z Tractor a call. https://www.a-ztractor.com/ Yep, Lincoln should have what your looking for, he had what I've needed in the past five or six years. Share this post Link to post Share on other sites
