squonk 45,402 #1 Posted February 23, 2021 I was going thru my parts piles and came across this starter. I'm almost positive it came off of a 74 C-160 that was toast. But it's different than any Kohler starter I've normally seen. Mount os on top and it wraps around to the bendix end. It's WH red with like 20 teeth. It still had the positive cable on it that was connected to a solenoid mounted on a flat bracket with the condenser on it as well. Maybe it was just acquired in a pile but anybody recognize this rascal? It says Bosch SMH 12 on it. Share this post Link to post Share on other sites
stevasaurus 23,568 #2 Posted February 23, 2021 That looks like a "high" mount starter. The lows are on the Kohlers 10, 12, 14, maybe 16. If you check the Kohler manual you will see the High mount starter there. 3 Share this post Link to post Share on other sites
squonk 45,402 #3 Posted February 23, 2021 4 minutes ago, stevasaurus said: That looks like a "high" mount starter. The lows are on the Kohlers 10, 12, 14, maybe 16. If you check the Kohler manual you will see the High mount starter there. My Kohler manual calls it a "wound field starter" as opposed to the permanent magnet type. doesn't say what it fits. If it is a small block starter I have no idea how I acquired it. I'm thinkin maybe someone threw it at me at the Big Show when I was walking back and forth. 5 Share this post Link to post Share on other sites
WHX?? 54,634 #4 Posted February 23, 2021 11 minutes ago, squonk said: someone threw it at me at the Big Show when I was walking back and forth. Ahhh... that explains the head wound and slurred speech...... here we thought it was natural 8 Share this post Link to post Share on other sites
squonk 45,402 #5 Posted February 23, 2021 11 minutes ago, WHX24 said: Ahhh... that explains the head wound and slurred speech...... here we thought it was natural I hear myself fine. Must be you! 1 6 Share this post Link to post Share on other sites
WHX?? 54,634 #6 Posted February 23, 2021 19 minutes ago, squonk said: I hear myself fine. Must be you! Cause you are the only one that listens to you?!?!? 1 1 Share this post Link to post Share on other sites
squonk 45,402 #7 Posted February 23, 2021 Yup. Even the dogs ignore me! 5 Share this post Link to post Share on other sites
Ed Kennell 44,720 #8 Posted February 23, 2021 1 hour ago, squonk said: Yup. Even the dogs ignore me! Ed Dog is always sittin up and lisnen to the Squonk. 1 9 Share this post Link to post Share on other sites
oldredrider 2,553 #9 Posted February 23, 2021 Looks like a K161/ K181 starter to me. Should have 16 teeth. 1 Share this post Link to post Share on other sites
Stepney 2,357 #10 Posted February 24, 2021 Yes, the old wound field starter, low mount. They came both like yours, and also with a cast aluminum bracket. Friend has one on a 16hp Speedex, which just so happens to be red. Had a heck of a time finding his when it failed a few years ago. They aren't common. As for WH uses.. I have no idea, besides maybe a D-160? Share this post Link to post Share on other sites
squonk 45,402 #11 Posted February 24, 2021 I have no idea on how I got it! Share this post Link to post Share on other sites
rjg854 12,836 #12 Posted February 24, 2021 Got CRS Mike along with all those other ailments 1 4 Share this post Link to post Share on other sites
Pullstart 68,790 #13 Posted February 24, 2021 17 hours ago, squonk said: My Kohler manual calls it a "wound field starter" as opposed to the permanent magnet type. doesn't say what it fits. If it is a small block starter I have no idea how I acquired it. I'm thinkin maybe someone threw it at me at the Big Show when I was walking back and forth. Maybe it was the house supplied parking brake at the bus stop... Share this post Link to post Share on other sites
oliver2-44 11,207 #14 Posted February 24, 2021 All this witty batter just makes me want to get to the Big Show to witness it even more. 3 Share this post Link to post Share on other sites
stevasaurus 23,568 #15 Posted February 24, 2021 @oliver2-44 If you want to take part in the "Real Witty Banter" , You need to join us at the Tail Gate of Knowledge evenings. 3 Share this post Link to post Share on other sites
