The Tuul Crib 7,354 #1 Posted February 22, 2021 Since I swapped out the crank and ended up with a smaller PTO shaft I had to use a larger diameter drive pulley. The belt was a 7473 I believe 81 1/2 inches. Any ideas what belt number this may be? Share this post Link to post Share on other sites
953 nut 67,489 #2 Posted February 22, 2021 I always have some old belts hanging around and when I have a need for an odd or unknown size belt I cut and splice an old belt or belts together by drilling holes near the end and stitching the pieces with tie wire. Another option would be to take the old belt to Tractor Supply, measure it and then get one the next larger size and one an inch longer than that, just return the one that won't fit. 2 Share this post Link to post Share on other sites
Ed Kennell 46,619 #3 Posted February 22, 2021 312H belt ? - Transmissions and transaxles - RedSquare Wheel Horse Forum This may help. 1 Share this post Link to post Share on other sites
Ed Kennell 46,619 #4 Posted February 22, 2021 This This is an 82" TSC belt on a 312H. The belt is too long. The idler pulley flange will cut a groove in the lower belt causing it to fail. This is an 81" TSC belt. Much better clearance. 1 1 Share this post Link to post Share on other sites
