Machria 77 #26 Posted February 26, 2021 5 hours ago, AHS said: @Machria it’s all repainted. The tires are new though, they are just stock size, 8” wheels on the front. understood. But what BRAND are those front tires ( the rubber)? I was unable to find tires of that shape, square style/flat. All the ones I see for sale are more rounded, meaning the tread profile is rounded when looking at them from the front. This ends up making less contact with the ground and doesn’t work as good, and looks like crap. Yours look like the original tires shape.... thanks... 1 Share this post Link to post Share on other sites
AHS 1,411 #27 Posted February 26, 2021 5 hours ago, Machria said: understood. But what BRAND are those front tires ( the rubber)? I was unable to find tires of that shape, square style/flat. All the ones I see for sale are more rounded, meaning the tread profile is rounded when looking at them from the front. This ends up making less contact with the ground and doesn’t work as good, and looks like crap. Yours look like the original tires shape.... thanks... Oh ok! Deestone D265 18x6.5x8 Share this post Link to post Share on other sites
Machria 77 #28 Posted February 27, 2021 1 hour ago, AHS said: Oh ok! Deestone D265 18x6.5x8 Got it, thanks! 1 Share this post Link to post Share on other sites
Machria 77 #29 Posted February 27, 2021 Here is what my tires look like, from amazon... MaxAuto 18X6.50-8 18x6.5x8 Turf Saver Lawn Mower Tire 4PR, Set of 2 See how they are "rounded" instead of flat/square? Share this post Link to post Share on other sites
ebinmaine 63,150 #30 Posted February 27, 2021 39 minutes ago, Machria said: Here is what my tires look like, from amazon... MaxAuto 18X6.50-8 18x6.5x8 Turf Saver Lawn Mower Tire 4PR, Set of 2 See how they are "rounded" instead of flat/square? How much air pressure do you have in there? Share this post Link to post Share on other sites
Machria 77 #31 Posted February 27, 2021 17 hours ago, ebinmaine said: How much air pressure do you have in there? Doesn't matter, they keep that shape... When I first had them mounted, the guy at shop had them blown up full blast, a bit over what the rating said on side (can't remember off hand what psi was...). I immediately thought, oh, he just over filled them, let some air out and they will flatten out.... nope. I have them almost flat, still rounded... 1 Share this post Link to post Share on other sites
pfrederi 17,147 #32 Posted February 27, 2021 10 minutes ago, Machria said: Doesn't matter, they keep that shape... When I first had them mounted, the guy at shop had them blown up full blast, a bit over what the rating said on side (can't remember off hand what psi was...). I immediately thought, oh, he just over filled them, let some air out and they will flatten out.... nope. I have them almost flat, still rounded... What model WH did the wheels come from? Raiders Chargers Electros used narrower wheels they used 16 5.50 x 8. Wider (6.50) tires will look a bit ballooned 1 Share this post Link to post Share on other sites
Machria 77 #33 Posted February 27, 2021 GT14 Same size tire that came off it... which were square.... it's these particular tires, they are just a rounded tire.... 1 Share this post Link to post Share on other sites
