ebinmaine 73,651 #1 Posted February 17, 2021 The stack on Cinnamon Horse C160 seeps between the muffler and standpipe. Straight fit. No threads or flanges etc. Is there a high temp sealer that works for that?? 2 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #2 Posted February 17, 2021 , what's high temperature and seals to pieces of metal together, starts with a W... ... Sorry Eric I had too, they do make a muffler "joint" or patching compound I'm sure you had to have seen in your parts store days but it works about 50/50 if that. 2 2 Share this post Link to post Share on other sites
rjg854 12,374 #3 Posted February 17, 2021 There is a orange colored silicone, made especially for sealing metal chimney sections, like Metalbestos. I'm not sure if would work for exhaust stacks/ mufflers. 1 Share this post Link to post Share on other sites
DennisThornton 4,771 #4 Posted February 17, 2021 More than one. Sodium silicate base with a filler. Muffler/exhaust sealers. Some in a tube, some a tin. Some just add water powders. I've had good luck with minor leaks. 2 Share this post Link to post Share on other sites
ebinmaine 73,651 #5 Posted February 17, 2021 34 minutes ago, WVHillbilly520H said: , what's high temperature and seals to pieces of metal together, starts with a W... ... Sorry Eric I had too, they do make a muffler "joint" or patching compound I'm sure you had to have seen in your parts store days but it works about 50/50 if that. Did actually think about welding but the top piece is chrome and I didn't want to screw it up. Good reason to learn how to braze maybe? I've had about the same luck with the muffler sealers over the years.... 1 Share this post Link to post Share on other sites
Pullstart 67,415 #6 Posted February 17, 2021 What about a header wrap on the bottom portion after you weld/braze it? 1 Share this post Link to post Share on other sites
squonk 44,129 #7 Posted February 17, 2021 (edited) The best exhaust sealer. Available at Napa $12.50 Love the warning that it's flammable. But it is the nuts! Edited February 17, 2021 by squonk 3 1 Share this post Link to post Share on other sites
peter lena 9,348 #8 Posted February 17, 2021 was going to suggest a very thin rapping piece of s/s shim stock to firm up the gap , available at local h/w stores , pete 1 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #9 Posted February 17, 2021 34 minutes ago, squonk said: The best exhaust sealer. Available at Napa $12.50 Love the warning that it's flammable. But it is the nuts! I don't promote my past employer of 22 years, much these days, as in "WALKER" which BTW is the only Walker/Tenneco "aftermarket" exhaust factory in the USA right here in VA. Share this post Link to post Share on other sites
ebinmaine 73,651 #11 Posted February 17, 2021 15 minutes ago, pullstart said: Standard issue catalytic converter substitute pipe 1 1 1 Share this post Link to post Share on other sites
Handy Don 14,272 #12 Posted February 17, 2021 13 minutes ago, ebinmaine said: Standard issue catalytic converter substitute pipe Clearly not running in a place does emissions testing with annual inspections! 1 3 Share this post Link to post Share on other sites
Pullstart 67,415 #13 Posted February 17, 2021 Annual inspections? Emissions? Never heard of em.. I think if they introduced that in Michigan, there would be a world of hurtin’ going on! 1 2 1 Share this post Link to post Share on other sites
DennisThornton 4,771 #14 Posted February 17, 2021 20 minutes ago, pullstart said: Annual inspections? Emissions? Never heard of em.. I think if they introduced that in Michigan, there would be a world of hurtin’ going on! Really! OMG! I just assume it was nationwide by now! "Check Engine" means old inspection sticker comes off and no new inspection sticker which will mean a ticket sooner or later. 1 2 Share this post Link to post Share on other sites
Pullstart 67,415 #15 Posted February 17, 2021 17 minutes ago, DennisThornton said: Really! OMG! I just assume it was nationwide by now! "Check Engine" means old inspection sticker comes off and no new inspection sticker which will mean a ticket sooner or later. I thought that meant open the hood and look at it! Looks good! Let’s roll! 7 Share this post Link to post Share on other sites
ebinmaine 73,651 #16 Posted February 17, 2021 21 minutes ago, DennisThornton said: Really! OMG! I just assume it was nationwide by now! "Check Engine" means old inspection sticker comes off and no new inspection sticker which will mean a ticket sooner or later. That's how it is in Massachusetts and also certain counties in Maine 1 Share this post Link to post Share on other sites
lynnmor 7,947 #17 Posted February 17, 2021 In PA they plug in to read any codes, check the gas cap and charge about $30. Even if you have the low mileage exemption, they still charge the same to slap on the exempt sticker. It is just a money grab backed by the Garagemens Association, the $30 tells you that your check engine light is on or off, but you already knew that. Share this post Link to post Share on other sites
pacer 3,177 #18 Posted February 17, 2021 State Inspections...hah! OH, we've got them here in La and if followed the criteria for passage is fairly extensive. Started out $5 a year for about 5yrs, then went to $10 for a 2 years for about 6-8 yrs, is now $20 for a 3yr sticker. I reach in the glove box for the registration & insurance, get my license and a $20 out, and go in and the guy fills in the book, grabs a new sticker & scraper, slaps it on and away I go. Good little source of money for the gummit............ 2 Share this post Link to post Share on other sites
Handy Don 14,272 #19 Posted February 17, 2021 Kinda speechless at these replies... Share this post Link to post Share on other sites
Pullstart 67,415 #20 Posted February 17, 2021 I grew up being taught that punching out your cat will make power. Carbs are better than fuel injection. Rip off that computer. Roll coal. I now understand that tuning has come a long way. You can make clean power. Whod’a thunk? EB. Thought of another solution. High temp tape! 3 Share this post Link to post Share on other sites
cafoose 3,466 #21 Posted February 17, 2021 10 minutes ago, pullstart said: I grew up being taught that punching out your cat will make power. 8 Share this post Link to post Share on other sites
ebinmaine 73,651 #22 Posted February 17, 2021 16 minutes ago, cafoose said: Excellent. Absolutely excellent. 1 1 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,376 #23 Posted February 17, 2021 1 hour ago, pullstart said: I grew up being taught that punching out your cat will make power. Carbs are better than fuel injection. Rip off that computer. Roll coal. I now understand that tuning has come a long way. You can make clean power. Whod’a thunk? EB. Thought of another solution. High temp tape! Working in the automotive exhaust field for 22 years, if the brick style "cat" ain't clogged it doesn't restrict flow much of any compared to the old pellets type. 2 Share this post Link to post Share on other sites
Tractorhead 9,212 #24 Posted February 17, 2021 We have here a inspection every 2 years, they charge nearly 100€ with a check lite on, there is no chance of the roadsafety ticket. the complete roadsafety checkup is at nearly 150€ - On truck‘s this check is every year. Except are Oldtimers before the Cat Aera, if they get history status, they can be as they where in their manufacting time. No retrofit of a Cat is necessary, it can be made but isn‘t a must. another reason, i prefer old Cars. On external repairs they should also last a little timeline, i know just an oversizepipe over the original, if originalpipe is on a spot rotten.But my experience shows me also, there is rarely just one single spot, it‘s mostly larger. 3 Share this post Link to post Share on other sites
Maxwell-8 4,367 #25 Posted February 17, 2021 (edited) 7 hours ago, WVHillbilly520H said: seals to pieces of metal together, starts with a W... i did an exaust, and welded it up, but my welder coudn't weld such tin pipe. so i had some holes. And we are not allowed to have aftermarket exaust systems so to make it look stock and seal it up, i used cement sealer. After some high temp paint, it looked like stock and hasn't been leaking since. Edited February 17, 2021 by Maxwell-8 2 Share this post Link to post Share on other sites
