BeninCT 451 #1 Posted February 16, 2021 Mine came with this spot that looks like it was wire wheeled. Anyone have any luck with any black hi heat paint on this? Have to scuff and sand the whole thing obv 1 Share this post Link to post Share on other sites
Handy Don 15,219 #2 Posted February 16, 2021 Hi-heat paint worked just fine for me. Does stink for the first 10 minutes when you run it after the paint cures! 3 Share this post Link to post Share on other sites
ebinmaine 75,779 #3 Posted February 16, 2021 Pop the muffler off and use BBQ paint. Read the directions!!! It'll need to be baked to cure correctly. 4 Share this post Link to post Share on other sites
Achto 30,207 #4 Posted February 16, 2021 High temp paint, Grill Paint, VHT header paint. They will all work well. I have found that if you build up several layers for a thick finish, you may have issues with the paint pealing. I tend to do about 2 coats maximum. 5 Share this post Link to post Share on other sites
lynnmor 8,263 #5 Posted February 16, 2021 I use this with good success: 3 1 Share this post Link to post Share on other sites
ebinmaine 75,779 #6 Posted February 16, 2021 1 hour ago, lynnmor said: I use this with good success: Yessir. That's the one we use. 2 Share this post Link to post Share on other sites
953 nut 63,068 #7 Posted February 16, 2021 For best results you should remove the muffler, sand/bead blast it clean and then use the 2000 degree primer and 2000 degree paint following the instructions on the can. The most important thing is to bake the paint onto the muffler. Bake at 250°F (121°C) for 30 minutes and allow 30 minutes to cool. Bake at 400°F (204°C) for 30 minutes and allow 30 minutes to cool. Bake at 600°F (315°C) for 30 minutes and then allow 30 minutes to cool. Caution: Be sure not to exceed the heat tolerance of the least heat tolerant part. If you fear that the wife would kill you the alternative process would be to follow these steps. Run the vehicle at idle for 10 minutes and then allow 20 minutes to cool. Run vehicle at idle for 20 minutes, then let cool for 20 minutes. Run vehicle at normal operating conditions for 30 minutes, then allow vehicle to cool. 5 Share this post Link to post Share on other sites
squonk 44,871 #8 Posted February 16, 2021 VHT!!!! 1 2 Share this post Link to post Share on other sites
peter lena 9,559 #9 Posted February 16, 2021 agree with all above, most important detail is , surface prep , used a light sandpaper and CARB CLEANER to help remove any debris , that hi heat paint , made an old muffler look like new, pete 1 Share this post Link to post Share on other sites
Jeff-C175 7,207 #10 Posted February 16, 2021 I might consider the "Silver Satin" finish for that one myself... Share this post Link to post Share on other sites
BeninCT 451 #11 Posted February 16, 2021 6 hours ago, Jeff-C175 said: I might consider the "Silver Satin" finish for that one myself... I think black is beautiful in this case lol. Thanks to all who posted- will clean er up a little 2 Share this post Link to post Share on other sites
