haydendavid380 759 #1 Posted February 12, 2021 Are there detailed instructions on installing one that previously hasn't had one? Is everything included in the kit from Lowell? 2 Share this post Link to post Share on other sites
R Scheer 505 #2 Posted February 12, 2021 That looks like everyghing, the kit I bought from Lowell had everything I needed. I believe you have to specify hydro vs manual, the tube the cable runs in is different. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,489 #3 Posted February 12, 2021 This one should do it 1 Share this post Link to post Share on other sites
squonk 43,843 #4 Posted February 12, 2021 9 hours ago, haydendavid380 said: Are there detailed instructions on installing one that previously hasn't had one? Is everything included in the kit from Lowell? It's pretty much self explanatory as long as you have the holes in the rear of the tractor to mount it. Share this post Link to post Share on other sites
haydendavid380 759 #5 Posted February 12, 2021 34 minutes ago, squonk said: It's pretty much self explanatory as long as you have the holes in the rear of the tractor to mount it. If you don't, are they unable to use them? Where I assume the cross piece goes theres small pin holes, almost like marking a spot to drill, but certainly nothing big enough to drop parts right in. Share this post Link to post Share on other sites
squonk 43,843 #6 Posted February 12, 2021 What model are you putting this on? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,489 #7 Posted February 12, 2021 Looks like they became available in 1976. Garry Share this post Link to post Share on other sites
Blackhood Bill 722 #8 Posted February 12, 2021 @haydendavid380 Inhave purchased one from Lowell. Amazing piece. Very simple to install. But as stated above there is a different tube for a hydro versus a geared machine. Yes there is a hole already there for the cable to slide thru predrilled. I don’t remember if it came with instructions. I’m some of us here could take a picture or two if you needed it. Share this post Link to post Share on other sites
haydendavid380 759 #9 Posted February 12, 2021 1 hour ago, squonk said: What model are you putting this on? B80 Share this post Link to post Share on other sites
squonk 43,843 #11 Posted February 12, 2021 Download the file Gary posted. You will see the holes needed. If your tractor is Pre 76 I don't think that kit works but I may be wrong. I wanted to put one on my 76 C-160 but my rear bracket was different like yours Share this post Link to post Share on other sites
haydendavid380 759 #12 Posted February 13, 2021 On 2/12/2021 at 9:00 AM, squonk said: Download the file Gary posted. You will see the holes needed. If your tractor is Pre 76 I don't think that kit works but I may be wrong. I wanted to put one on my 76 C-160 but my rear bracket was different like yours Does that mean pre-76 tractors are just SOL on running rear implements? I could have sworn I've seen slot hitches on early tractors Share this post Link to post Share on other sites
pfrederi 18,685 #13 Posted February 13, 2021 They used just a cable from the tractor lift arm through the tube over the tranny. Share this post Link to post Share on other sites
pfrederi 18,685 #14 Posted February 13, 2021 (edited) 8-5511 and 8-5521 are slot and clevis examples https://www.wheelhorseforum.com/search/?q=8-5511&quick=1&type=downloads_file&nodes=21 https://www.wheelhorseforum.com/files/file/2306-hitch-rear-slot-1969-1975-implement-8-5521-om-ipl-dnapdf/ Edited February 13, 2021 by pfrederi Share this post Link to post Share on other sites
haydendavid380 759 #15 Posted February 14, 2021 Thank you! So if I'm reading that right, all I need is this? There should be a tunnel or tube on my tractor right? Share this post Link to post Share on other sites
haydendavid380 759 #16 Posted February 14, 2021 I'll be darned, I've looked for that tube multiple times but there she is. Share this post Link to post Share on other sites
Handy Don 14,063 #17 Posted February 14, 2021 Just now, haydendavid380 said: I'll be darned, I've looked for that tube multiple times but there she is. Looks like you'll have a bit of a task clearing out the tube! There is some debate among members on lubrication in there. Some like good grease but others think it attracts/retains dirt that causes wear in this very exposed location so they use no lubrication. Some think graphite is the way to go. My cable is plastic coated and self-lubricating (way to sidestep the debate, eh? ). All up to you! Share this post Link to post Share on other sites
Lee1977 7,214 #18 Posted February 15, 2021 On 2/13/2021 at 9:21 PM, haydendavid380 said: I'll be darned, I've looked for that tube multiple times but there she is. On 2/13/2021 at 9:27 PM, Handy Don said: Looks like you'll have a bit of a task clearing out the tube! There is some debate among members on lubrication in there. Some like good grease but others think it attracts/retains dirt that causes wear in this very exposed location so they use no lubrication. Some think graphite is the way to go. My cable is plastic coated and self-lubricating (way to sidestep the debate, eh? ). All up to you! Share this post Link to post Share on other sites
