cschannuth 3,821 #1 Posted February 10, 2021 (edited) I was plowing snow today and my charger 12 started to run a little bit rough. I topped off the fuel tank and took off again and as I was backing up the entire air filter assembly was laying on the ground after I looked up from backing up. The three screws that attach it to the carburetor had come loose inside the housing. I put a little medium duty Loctite on the three screws and reinstalled it and everything looked fine but it appeared that I could see a little bit of light between the filter housing and the face of the carb. Is there supposed to be a gasket between there? Without it it seems like it might be a spot for air to bypass the filter and go directly into the carburetor. Edited February 10, 2021 by cschannuth 1 1 Share this post Link to post Share on other sites
WHX?? 58,236 #2 Posted February 10, 2021 (edited) Yes there is a gasket there Craig. Bigger question is did the screws get ingested by the engine? Edited February 10, 2021 by WHX24 5 Share this post Link to post Share on other sites
WHX?? 58,236 #3 Posted February 10, 2021 (edited) 20 minutes ago, cschannuth said: fuel air filter assembly Typo? Edited February 10, 2021 by WHX24 Share this post Link to post Share on other sites
cschannuth 3,821 #4 Posted February 10, 2021 26 minutes ago, WHX24 said: Yes there is a gasket there Craig. Bigger question is did the screws get ingested by the engine? Nope, everything came off in one piece and the screws and the star washers were inside the air filter housing. If there was a gasket there it might have been sucked in because I can’t find it anywhere. But it was running for a good two minutes while I collected everything and got everything back inside to assess the situation. 3 Share this post Link to post Share on other sites
cschannuth 3,821 #5 Posted February 10, 2021 21 minutes ago, WHX24 said: Typo? Yep. Thanks. Share this post Link to post Share on other sites
cschannuth 3,821 #6 Posted February 10, 2021 31 minutes ago, WHX24 said: Yes there is a gasket there Thank you so much. Can I get just that one gasket somewhere? Is that something my local auto parts store would have? Share this post Link to post Share on other sites
pfrederi 21,189 #7 Posted February 10, 2021 Be cheaper faster to make one. it is nothing special. Cereal box or some gasket paper 6 Share this post Link to post Share on other sites
cschannuth 3,821 #8 Posted February 10, 2021 8 minutes ago, pfrederi said: Be cheaper faster to make one. it is nothing special. Cereal box or some gasket paper I do love cereal… LOL. Thanks! 3 Share this post Link to post Share on other sites
JoeM 10,312 #10 Posted February 10, 2021 (edited) And I had one were one of the screws was just a little bit longer than the other and If it was put in the wrong place would not seal up the housing. You could get by with a touch of silicone if you let it cure over night. just another option. Edited February 10, 2021 by JoeM 3 Share this post Link to post Share on other sites
roadapples 6,987 #11 Posted February 10, 2021 I've always worried about those screws coming loose and getting sucked into the engine. Maybe unlikely. But I've started using 3/4" studs with loctite and nylock nuts. 2 Share this post Link to post Share on other sites
pfrederi 21,189 #12 Posted February 11, 2021 1 hour ago, JoeM said: And I had one were one of the screws was just a little bit longer than the other and If it was put in the wrong place would not seal up the housing. You could get by with a touch of silicone if you let it cure over night. just another option. Yes on some the two side screws are short to clear the choke shaft... 3 Share this post Link to post Share on other sites
WHX?? 58,236 #13 Posted February 11, 2021 (edited) 4 hours ago, cschannuth said: Nope, everything came off in one piece and the screws and the star washers were inside the air filter housing. If there was a gasket there it might have been sucked in because I can’t find it anywhere. You got blind out house lucky then Craig .... yep one of my fears of them shaking loose. I doubt the gasket got sucked in tho they usually get stuck on the back plate. Those gaskets might be all over fleabay but I like Joe's idea too. I wouldnt think the woes of your running rough would be caused by it (gasket) missing? Edited February 11, 2021 by WHX24 1 Share this post Link to post Share on other sites
cschannuth 3,821 #14 Posted February 11, 2021 I ordered a new one for $5 on partstree and made a temporary one out of a piece of cardboard for now. It worked fine. The carb was a litttle loose too. This tractor seems to vibrate lots of bots/screws loose. 2 Share this post Link to post Share on other sites
WHX?? 58,236 #15 Posted February 11, 2021 (edited) 11 minutes ago, cschannuth said: bots/screws loose. Kinda like @squonk!?!?!? Forgot to add guy that is one fine tractor ther guy.... love them shoes and hub caps. Looks to be a early large diameter steering wheel on it? Edited February 11, 2021 by WHX24 Add 3 Share this post Link to post Share on other sites
cschannuth 3,821 #16 Posted February 11, 2021 17 minutes ago, WHX24 said: Forgot to add guy that is one fine tractor ther guy.... love them shoes and hub caps. Looks to be a early large diameter steering wheel on it? Thanks! I’m still not really sure if it’s a 1277 or an early 68 Charger 12 but I really like it. It’s really fast and fun. I pushed a little snow every day this week at my house and the neighbors across the street. It worked great (until I lost the air filter assembly-haha). I need to do a bit of adjusting because the motion lever works its way all the way forward if you let go of it. 1 5 Share this post Link to post Share on other sites
WHX?? 58,236 #17 Posted February 11, 2021 9 minutes ago, cschannuth said: I’m still not really sure if it’s a 1277 or an early 68 Charger 12 No matter still a nice lookin rig. Was just a thread on that motion lever problem. Turned out it was the plastic hydro cam plate broke and the retainers that hold it down. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #18 Posted February 11, 2021 6 hours ago, WHX24 said: Typo? Combo! You know! 2 Share this post Link to post Share on other sites
cschannuth 3,821 #19 Posted February 11, 2021 20 minutes ago, WHX24 said: Turned out it was the plastic hydro cam plate broke and the retainers that hold it down. I’m hoping that I can just snug the handle friction a bit to take care of it. 1 Share this post Link to post Share on other sites
The Tuul Crib 7,354 #20 Posted February 11, 2021 41 minutes ago, cschannuth said: I’m hoping that I can just snug the handle friction a bit to take care of it. If it doesn't it might be a good excuse to buy a new carburetor eh! Share this post Link to post Share on other sites
squonk 48,166 #21 Posted February 11, 2021 10 hours ago, WHX24 said: Kinda like @squonk!?!?!? I use Loctite and star lock washers ya Galoot! 3 Share this post Link to post Share on other sites
cschannuth 3,821 #22 Posted February 11, 2021 (edited) 15 hours ago, WHX24 said: Turned out it was the plastic hydro cam plate broke and the retainers that hold it down. I wonder if part of the issue might be the cam plate. I would think I should be able to feel some sort of difference between forward neutral and reverse and I don’t. It just works smoothly with the lever all the way forward when I pull it all the way back to reverse. Edited February 11, 2021 by cschannuth Share this post Link to post Share on other sites
