pfrederi 21,184 #1 Posted January 29, 2021 Opened up the M-18 on my 418A. Was just planning on decarbon as she has been running OK, no smoking, was even planning on adding an oil filter.. Hour meter has 1254 but didn't work when I got it and has had periodic outages since. I am sure she has more hours. Had to replace the front tires as one was actually worn. Hydro works well. However, I don't think you should be able to wiggle the pistons in the cylinders with finger pressure.... Option 1# Started looking at parts, some are a bit hard to come by in oversize. Everything is doubled with twin... Parts (aftermarket) are going to be over $325. Based on what my machine shop has charged for a K single I am guessing he will want $250-300. Allowing for some unforeseen stuff we are talking $700. (assuming I can get all the over under sizes it may need. Option #2 Predator 22 is just a bit more than that (depending on coupons) Option #3 Button it back up run it till it gets really bad. I have 3 other 48" mower tractors (That is her job since she was fired from snowblower duty. hydro lift takes for ever to decide to work). 2 C-175-8 and a Charger 16 Option #3a Button up and sell quick before she starts to smoke 2 Share this post Link to post Share on other sites
WHX?? 58,230 #2 Posted January 29, 2021 (edited) Same boat as you with a KT19... I'm going with option 3 and let her blow. Maybe do a pred. or a repo with a series 2 from a donor tractor. I do have a Onan 20 I would have to put about 600 or 700 in. A Super C with an Onan would be cool. Did it use oil Paul? Edited January 30, 2021 by WHX24 2 Share this post Link to post Share on other sites
pfrederi 21,184 #3 Posted January 29, 2021 24 minutes ago, WHX24 said: Same boat as you with a KT17... I'm going with option 3 and let her blow. Maybe do a pred. or a repo with a series 2 from a donor tractor. I do have a Onan 20 I would have to put about 600 or 700 in. A Super C with an Onan would be cool. Did it use oil Paul? No unusual oil use, but then she isn't worked very hard a couple hours mowing Share this post Link to post Share on other sites
squonk 48,163 #4 Posted January 29, 2021 How about plopping a nice K321 in it? 1 Share this post Link to post Share on other sites
pfrederi 21,184 #5 Posted January 29, 2021 I will have a nice 301 in a month or so. Not sure that and a hydro will do really well with a 48 deck... Share this post Link to post Share on other sites
SylvanLakeWH 32,613 #6 Posted January 29, 2021 Option 3... Not smoking... not using oil... meh... let her run... 2 Share this post Link to post Share on other sites
cod 136 #7 Posted January 29, 2021 Hard choices at times as none of us are rolling in $ and parts are getting harder to find. I think #3 is what most us have to look forward to once the M-18's go even though in my option they're are good engine. I've got 2 418's and while having a spare set of parts comes in handy, the 'spare engine' has almost 1600hrs on it and I waffle about rebuilding it. You seem to have a good handle on maintaining your equipment so there's a fair chance that you can get many more years of mowing before having to change the engine. Good luck! 1 Share this post Link to post Share on other sites
953 nut 69,559 #8 Posted January 30, 2021 4 hours ago, pfrederi said: Option #3 Button it back up run it till it gets really bad. Considering the size of your herd I would just drive it since it isn't smoking or giving you problems. Share this post Link to post Share on other sites
WHX?? 58,230 #9 Posted January 30, 2021 2 hours ago, pfrederi said: I will have a nice 301 in a month or so. Not sure that and a hydro will do really well with a 48 deck... I personally wouldn't try to spin a 48 with nothing less than a sweet 16. Especially on a hydro. 'Nother ? Why was it taken off blower work, lack of power? Also were the heads and pistons washed clean of carbon indicating oil useage? If no run her like you stole her, option 3. Just keep in mind piston/cylinder scoring is likely to happen and might make a rebuild down the road more of a job or worse take her out of 30 over if ever decided to go that route. Not an issue if a repo is in mind and you decide to keep her. Share this post Link to post Share on other sites
richmondred01 2,393 #10 Posted January 30, 2021 Opinion 1. The m18 is a great engine. The only down side is non adjustable valves. Its not a bad job. Much easier then the onans. I think your price is spot on with the machine work and parts. Share this post Link to post Share on other sites
wh5208speed 677 #11 Posted January 30, 2021 I would look for a Craftsman GT 6000 as a donor tractor. It has the twin cylinder Kohler Magnum with the same output shaft. They can be had pretty cheap ($250-700 depending on the condition). 1 Share this post Link to post Share on other sites
pfrederi 21,184 #12 Posted January 30, 2021 (edited) 1 hour ago, WHX24 said: I personally wouldn't try to spin a 48 with nothing less than a sweet 16. Especially on a hydro. 'Nother ? Why was it taken off blower work, lack of power? Also were the heads and pistons washed clean of carbon indicating oil useage? If no run her like you stole her, option 3. Just keep in mind piston/cylinder scoring is likely to happen and might make a rebuild down the road more of a job or worse take her out of 30 over if ever decided to go that route. Not an issue if a repo is in mind and you decide to keep her. Not power it was the eaton hydro and the common problem of delay in operation of the lift. I would start her up in the shop and it would take a minute or two before it would pick up the blower so i could move it outside to warm up. (Had to maneuver a bit around my truck t get out and it didn't do well with the blower on the ground.. Filled the shop with fumes. My sunstrands will pick up and move out immediately. There was plenty of carbon build up on the head and top side of the piston. I had Charger 12 with a 301 did OK with a 48 (better than my neighbors 19 hp JD big Box store version) Edited January 30, 2021 by pfrederi 1 Share this post Link to post Share on other sites
pfrederi 21,184 #13 Posted January 30, 2021 40 minutes ago, richmondred01 said: Opinion 1. The m18 is a great engine. The only down side is non adjustable valves. Its not a bad job. Much easier then the onans. I think your price is spot on with the machine work and parts. In looking around it is unclear if piston/rings are available in .010 or .020 over, also are rods available in .010 under. Share this post Link to post Share on other sites
JoeM 10,310 #14 Posted January 30, 2021 Maybe another economical option, Briggs Vanguard V twin out of a Cub. I've done two 16HP and they run real good. Some of those 90 ish vintage cubs are going for less then 300 and might be able to hear it run before you buy. Down side was the exhaust needing modified and 1 inch to 1 1/8 sleeve for drive pulley. 3 1 Share this post Link to post Share on other sites
Bill D 3,158 #15 Posted January 30, 2021 5 hours ago, wh5208speed said: I would look for a Craftsman GT 6000 as a donor tractor. It has the twin cylinder Kohler Magnum with the same output shaft. They can be had pretty cheap ($250-700 depending on the condition). Any Magnum from another machine will require use of an electric clutch. Only WH spec Magnums had the necessary thrust bearings. Also, some older Sears tractors came with Briggs boxer twins that can be swapped in. Those engines should have ball bearings on the crankshaft and be able to handle the side loading from the PTO. Sears also put Onans in some tractors. Briggs boxer twins can also be found in some older Snapper tractors as well. 1 Share this post Link to post Share on other sites
richmondred01 2,393 #16 Posted January 30, 2021 11 hours ago, pfrederi said: In looking around it is unclear if piston/rings are available in .010 or .020 over, also are rods available in .010 under. my suppler no longer carry’s them however, I will message you a link to someone who does. 1 Share this post Link to post Share on other sites
JohnD 145 #17 Posted January 31, 2021 22 hours ago, pfrederi said: I would start her up in the shop and it would take a minute or two before it would pick up the blower Yup, sounds like my C-175. I start it up and let it warm up in the shed while I clear the snow out front with a shovel. After about a minute or two I'll hear the KT-17 growl a little and that's my signal that the Eaton is warmed up. Keeps the chipmunks and mice away too, but that's another thread... Share this post Link to post Share on other sites
Bill D 3,158 #18 Posted February 1, 2021 @gwest_ca. Garry do you have a chart from Briggs that shows which boxer twins came with ball bearing supported crankshafts. Someone gave me one awhile back in another thread, but I can't find it now. Thanks. Share this post Link to post Share on other sites
pfrederi 21,184 #19 Posted February 1, 2021 58 minutes ago, Bill D said: @gwest_ca. Garry do you have a chart from Briggs that shows which boxer twins came with ball bearing supported crankshafts. Someone gave me one awhile back in another thread, but I can't find it now. Thanks. Share this post Link to post Share on other sites
Bill D 3,158 #20 Posted February 1, 2021 On 1/30/2021 at 2:02 AM, JoeM said: Maybe another economical option, Briggs Vanguard V twin out of a Cub. I've done two 16HP and they run real good. Some of those 90 ish vintage cubs are going for less then 300 and might be able to hear it run before you buy. Down side was the exhaust needing modified and 1 inch to 1 1/8 sleeve for drive pulley. I like this. Any more pictures, or is there a thread detailing how exactly you did the swap? Thanks. Bill Share this post Link to post Share on other sites
JoeM 10,310 #21 Posted February 1, 2021 1 hour ago, Bill D said: Any more pictures That is about all I got. I know I had to raise up about an inch to make the belt alignment. I One machine I used channel the other was threaded blocks welded to the original 520 plate. And the ignition switch is different because the vanguards don't use a coil. Share this post Link to post Share on other sites
Bill D 3,158 #22 Posted February 2, 2021 7 hours ago, pfrederi said: Thanks. This may come in handy some day. Share this post Link to post Share on other sites
