snowhound 106 #1 Posted January 28, 2021 I want to put and older snow plow on a 310-8 and need a newer style lever to angle the blade. SLE Equipment has what I need has anyone done business with them and would you do business with them again? Share this post Link to post Share on other sites
953 nut 63,388 #2 Posted January 29, 2021 I have no information about SLE Eq. but the blade angle lever is easy enough to build. Have you considered making your own? Share this post Link to post Share on other sites
stevasaurus 23,521 #3 Posted January 29, 2021 When you say..."older blade" do you mean the "A" frame type? If so, you may find that when mounted you may not be able to angle the blade because it will hit the front tires. older type newer type Share this post Link to post Share on other sites
snowhound 106 #4 Posted January 30, 2021 It's like the second photo and clears the tires when angled but the arm to angle the blade doesn't clear the muffler. I believe I need one of the arms that has two 90 degree bends and uses a cable to pull the pin to angle the blade Share this post Link to post Share on other sites
953 nut 63,388 #5 Posted January 30, 2021 10 minutes ago, snowhound said: It's like the second photo and clears the tires when angled but the arm to angle the blade doesn't clear the muffler. I believe I need one of the arms that has two 90 degree bends and uses a cable to pull the pin to angle the blade I just sent you a PM with pictures of the later model arm. Share this post Link to post Share on other sites
WVHillbilly520H 10,377 #6 Posted January 30, 2021 On 1/28/2021 at 3:32 PM, snowhound said: I want to put and older snow plow on a 310-8 and need a newer style lever to angle the blade. SLE Equipment has what I need has anyone done business with them and would you do business with them again? I have and they were fine to deal with, now that being said we can't count on shipping times these days... 11 hours ago, 953 nut said: I have no information about SLE Eq. but the blade angle lever is easy enough to build. Have you considered making your own? Richard the angle from seat lever he insist likely referring to has multiple bends in it to clear the muffler and foot rest... Not too easy to home fab without a pattern and a few tools. Share this post Link to post Share on other sites
snowhound 106 #7 Posted January 31, 2021 do you have a part number? Share this post Link to post Share on other sites
WVHillbilly520H 10,377 #8 Posted January 31, 2021 2 hours ago, snowhound said: do you have a part number? Number 25... TORO part # 94-6686-01. https://www.partstree.com/models/79350-toro-48-snow-dozer-blade-sn-099000001-099999999-1999/frame-assembly-1/. 1 Share this post Link to post Share on other sites
Horse Newbie 7,400 #9 Posted January 31, 2021 Does anybody know if Lowell (@Wherlhorseman) makes them ? I know I got one from him for my 520H. 1 Share this post Link to post Share on other sites
