71_Bronco 1,072 #1 Posted January 12, 2021 Need a set of Throttle and Choke Cables for my '62 Lawn Ranger. It has the holes in the dash for the cables to pass through (don't know off-hand what the holes size is). If I recall correctly, some people were disappointed with the quality of the Stens replacements (I could be wrong). I see Lowel @wheelhorseman has a pair on his site, but not sure how these compare to the older OEM ones and the modern Stens one. I could also check out A-Z, but I don't know what I need for part numbers. Any thoughts or ideas? Thanks! 3 Share this post Link to post Share on other sites
ebinmaine 77,324 #2 Posted January 12, 2021 @Achto has led me to psep.biz to purchase cables and they are of good quality but I don't know which ones you would need. 2 Share this post Link to post Share on other sites
Stepney 2,357 #3 Posted January 12, 2021 Something as old as that, wouldn't it have had the smaller diameter, thicker knobs? Not sure I've ever seen them aftermarket. 1 Share this post Link to post Share on other sites
Achto 30,991 #4 Posted January 12, 2021 3 hours ago, 71_Bronco said: Need a set of Throttle and Choke Cables for my '62 Lawn Ranger. This cable set will match the look of the original set and will fit the holes in the dash. Only down side is that it does not say if the throttle cable has a locking mechanism on it. I do plan on purchasing a set of these for my 753 in the future. https://www.ebay.com/itm/Willys-Kaiser-Jeep-CJ2A-CJ3A-CJ3B-CJ5-Tractor-Car-Truck-Choke-Throttle-Cable/182497006421?hash=item2a7dab5355:g:Yr0AAOSwWxNY0ECr Share this post Link to post Share on other sites
Achto 30,991 #5 Posted January 12, 2021 3 hours ago, ebinmaine said: @Achto has led me to psep.biz Apparently Pat's is going through some web site changes, with their new site being "psep1.biz". This new site SUCKS !!! I can't find anything on it, and their old site gives a security warning when you go to order. I ordered through their old site this last time & did not have an issue, but if you feel unsafe ordering from the old site just write you part numbers down & call it in. FYI 1 1 Share this post Link to post Share on other sites
71_Bronco 1,072 #6 Posted January 13, 2021 1 hour ago, Achto said: This cable set will match the look of the original set and will fit the holes in the dash. Only down side is that it does not say if the throttle cable has a locking mechanism on it. I do plan on purchasing a set of these for my 753 in the future. https://www.ebay.com/itm/Willys-Kaiser-Jeep-CJ2A-CJ3A-CJ3B-CJ5-Tractor-Car-Truck-Choke-Throttle-Cable/182497006421?hash=item2a7dab5355:g:Yr0AAOSwWxNY0ECr Those are pretty nice, I like the writing of "throttle" and "choke" rather than a C and T. Based on the pics, they dont look like a twist-to-lock set. How do you know these will fit? I can't see a spec on hole requirements. 1 Share this post Link to post Share on other sites
71_Bronco 1,072 #7 Posted January 13, 2021 1 hour ago, Achto said: Apparently Pat's is going through some web site changes, with their new site being "psep1.biz". This new site SUCKS !!! I can't find anything on it, and their old site gives a security warning when you go to order. I ordered through their old site this last time & did not have an issue, but if you feel unsafe ordering from the old site just write you part numbers down & call it in. FYI Just checked out the new site. Doesn't look like there's any picture or specs. I tried searching "choke cable" and a whole bunch came up, but no specs or pics, even when clicking each item Share this post Link to post Share on other sites
Achto 30,991 #8 Posted January 13, 2021 18 minutes ago, 71_Bronco said: How do you know these will fit? I can't see a spec on hole requirements. Got a buddy with a CJ2. Checked his out when he had it apart. 1 1 Share this post Link to post Share on other sites
Achto 30,991 #9 Posted January 13, 2021 21 minutes ago, 71_Bronco said: I tried searching "choke cable" and a whole bunch came up, but no specs or pics, even when clicking each item This is from their old site "which is still active" These cables match the ones used on the square hood models. The throttle does lock on these. 1 Share this post Link to post Share on other sites
