Gregor 4,848 #26 Posted January 12, 2021 I suspected this, the Tecumseh Manual confirmed it. Maybe I don't have a problem with the charging circuit. "In some cases an open circuit D.C. check cannot be made. An SCR (Silicon Controlled Rectifier) is located in the circuit which requires a minimum “turn on” voltage to allow it to conduct. Without the battery in the circuit this “turn on” voltage is not present. The SCR “senses” this and there will be no D.C. output from the regulator or rectifier." 1 Share this post Link to post Share on other sites
ebinmaine 79,573 #27 Posted January 12, 2021 Ahhh..... I've heard of car alternators that did that. Share this post Link to post Share on other sites
Handy Don 16,918 #28 Posted January 12, 2021 2 hours ago, Gregor said: Anyway, it's something I will have to investigate So you might start having fun after all? 1 Share this post Link to post Share on other sites
Gregor 4,848 #29 Posted January 12, 2021 I don't know why, but fun for me always seems to = $$$$$ Share this post Link to post Share on other sites
Handy Don 16,918 #30 Posted January 12, 2021 1 hour ago, Gregor said: I don't know why, but fun for me always seems to = $$$$$ "I don't know what he's up to but when he gets that look in his eye it's aways expensive!" Danny Kaye as Davis in White Christmas 1 Share this post Link to post Share on other sites
Gregor 4,848 #31 Posted January 14, 2021 The TVM 22o runs very well with the correct " Idle restrictor screw" in it. But the fuel delivery system is a bust. With the by-pass hose, the pump eventually quits pumping anything at all. Without the by-pass hose, it loads up the carb. Too much pressure I guess. If you are considering an electric fuel pump on anything, keep this in mind. I don't know if a shut off valve could be put in the line to meter the fuel, or if that would eventually ruin the pump. Share this post Link to post Share on other sites
Gregor 4,848 #32 Posted May 18, 2021 I was thinking of this tach. In past conversations, I think it was said, the reading actually had to be cut in half. But sometimes I don't remember so well. Share this post Link to post Share on other sites
Jeff-C175 7,209 #33 Posted May 18, 2021 33 minutes ago, Gregor said: I think it was said, the reading actually had to be cut in half Would that be the case for the 'twins' with the 'wasted spark' design? If it's a single cylinder, with only one spark per revolution I would think it would read correctly. Share this post Link to post Share on other sites
lynnmor 8,885 #34 Posted May 18, 2021 30 minutes ago, Jeff-C175 said: Would that be the case for the 'twins' with the 'wasted spark' design? If it's a single cylinder, with only one spark per revolution I would think it would read correctly. It does not matter if there are one or two cylinders, if the ignition is timed from the crank there will be a spark at each plug every revolution. 1 Share this post Link to post Share on other sites
Jeff-C175 7,209 #35 Posted May 18, 2021 31 minutes ago, lynnmor said: It does not matter if there are one or two cylinders, if the ignition is timed from the crank there will be a spark at each plug every revolution. Yep... I realized that after I sent. So a digital tach reading will in fact need to be halved. Share this post Link to post Share on other sites
