AHS 1,642 #1 Posted January 8, 2021 Ok, I’m looking for a term! The wires that connect onto the key switch, those female plugs with the little barb on them. I’ve checked the dealer, they don’t have any of those clips. I was going to check eBay. Share this post Link to post Share on other sites
1995 520H+96+97 939 #2 Posted January 8, 2021 Terminal female spade. 3 1 Share this post Link to post Share on other sites
ebinmaine 77,824 #3 Posted January 8, 2021 @953 nutnut....? I use regular 1/4 spades or buy the whole connector. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,067 #4 Posted January 8, 2021 2 2 Share this post Link to post Share on other sites
JAinVA 4,638 #5 Posted January 8, 2021 (edited) I got 100 of these from a vendor on E-bay for around $5.00 .They are barbed to be used in the plastic connectors. They are called female spade terminals as previously posted. Edited January 8, 2021 by JAinVA 2 Share this post Link to post Share on other sites
953 nut 64,651 #6 Posted January 8, 2021 You want to buy the Packard 56 terminals, they lock into the terminal block and hold tight. 3 Share this post Link to post Share on other sites
AHS 1,642 #7 Posted January 9, 2021 Thank you!! Packard 56 terminals! 😀Thank you guys! 1 1 Share this post Link to post Share on other sites
peter lena 9,797 #8 Posted January 9, 2021 AHS , NOTING YOUR WIRE SWITCH ISSUES , added a 4 ga cable from the corner of my engine to frame , and bolted it to the GROUND RAIL , next to the battery , 1 st picture and last picture , also shown are the easy mount battery tender plug in always available. adding those washers to the inside of the PTO LEVER , under the ground rail , really firms up the action and makes it very smooth . that ground cable really helped out my electrical issues , pete 2 Share this post Link to post Share on other sites
JohnD 145 #9 Posted January 9, 2021 They are also called 'quick disconnect' terminals. When I picked up my C-175 last fall the key is pretty wobbly in the ignition, so I picked up a spare ignition as an insurance policy; so far it is hanging on. Should I try and keep the 5-contact connector functioning, or just plan on replacing it with 5 new contacts when I pull it off? Share this post Link to post Share on other sites
ebinmaine 77,824 #10 Posted January 9, 2021 9 minutes ago, JohnD said: They are also called 'quick disconnect' terminals. When I picked up my C-175 last fall the key is pretty wobbly in the ignition, so I picked up a spare ignition as an insurance policy; so far it is hanging on. Should I try and keep the 5-contact connector functioning, or just plan on replacing it with 5 new contacts when I pull it off? Take a good look at it when you pop out the switch. If the terminals have ANY corrosion or looseness replace them ALL. 3 1 Share this post Link to post Share on other sites
RandyLittrell 3,944 #11 Posted January 10, 2021 https://theelectricaldepot.com/weather-pack-delphi-connectors/delphi-packard-metri-pack-56?zenid=88e3891ac599799dccd05ad5a07c5011 1 Share this post Link to post Share on other sites
