WheelhorseBob 1,550 #1 Posted January 8, 2021 Anyone have a trick to installing these crumby seals? I have installed axle bearings, input bearing, brake shaft bearing, axle and break shaft seals. The input shaft seal is becoming a real pita. I've already ruined two because it is so flimsy and nothing like the original. BTW i'm using SKF seals, is there a better option? Share this post Link to post Share on other sites
ebinmaine 77,549 #2 Posted January 8, 2021 I try to use one of the old bearings as a driver. 1 Share this post Link to post Share on other sites
ebinmaine 77,549 #3 Posted January 8, 2021 Or a deep socket that's just larger than the shaft... Share this post Link to post Share on other sites
WheelhorseBob 1,550 #4 Posted January 8, 2021 The metal outside edge is so flimsy it catches and distorts. I've installed a lot of seals but nothing as bad as these. The original seal is nothing like these, much stronger design. Share this post Link to post Share on other sites
ebinmaine 77,549 #5 Posted January 8, 2021 19 minutes ago, WheelhorseBob said: The metal outside edge is so flimsy it catches and distorts. I've installed a lot of seals but nothing as bad as these. The original seal is nothing like these, much stronger design. Any way you can get a wee little piece of sandpaper in there and set a chamfer to the lip? 1 Share this post Link to post Share on other sites
Maxwell-8 4,370 #6 Posted January 8, 2021 (edited) 42 minutes ago, WheelhorseBob said: SKF seals Is a good brand is far as we now here. I guess qualitysavings has gotten into everything and everywhere. Edited January 8, 2021 by Maxwell-8 1 Share this post Link to post Share on other sites
ri702bill 11,411 #7 Posted January 8, 2021 I will take the liberty to digress away from the original topic and add my less than humble opinion on Cost Reductions. I worked 14 years for a Tier 1 Automotive OEM, and cost reducing was a way of life. We each had a personal annual goal to achieve that would be brought up during annual performance reviews. I always shied away from buying a car during its first model year of the production run. I now realize that most if not all of the "Big 3" require suppliers to reduce the cost of what finished part they supply per year for the duration of the contract (sometimes up to 10%!!) All that is negotiated into the contract. I have seen a component part get cost reduced by as little as 1/10th of a penny - but at a million or more of that part per year it adds up. Now I feel better .......... Bill 4 1 Share this post Link to post Share on other sites
stevasaurus 23,627 #8 Posted January 8, 2021 click on this link... https://www.google.com/search?gs_ssp=eJzj4tLP1TcwMjOvNC1RYDRgdGDwEsjNL8nMz8vMSyktLinKTC0GAJ9ZCp0&q=seals skf 6105 site%3Amotionindustries.com&rlz=1C1CHBF_enUS865US865&oq=motionindustries&aqs=chrome.1.69i57j46i199i291j0j0i10i30l4j0i30.24175j0j15&sourceid=chrome&ie=UTF-8&ved=2ahUKEwjx47P6l43uAhVKAqwKHWZ6AU8Q2wF6BAgDEAE&ei=EsL4X_GSF8qEsAXm9IX4BA Which one did you get?? I would go with the middle one. Rather then the SKF seal, you could try National https://www.google.com/search?rlz=1C1CHBF_enUS865US865&sxsrf=ALeKk013AfiDAhkecjJPcBystb-Rph9RmA%3A1610138203265&ei=58P4X8zLAc3GsAWHyKaQCw&q=cross skf 6105 to national site%3Amotionindustries.com&gs_ssp=eJzj4tLP1TcwMjOvNC1RYDRgdGDwEsjNL8nMz8vMSyktLinKTC0GAJ9ZCp0&oq=&gs_lcp=CgZwc3ktYWIQARgBMgcIIxDqAhAnMg0ILhDHARCjAhDqAhAnMgcIIxDqAhAnMgcIIxDqAhAnMgcIIxDqAhAnMgcIIxDqAhAnMgcIIxDqAhAnMgcIIxDqAhAnMgcIIxDqAhAnMgcIIxDqAhAnUIfDF1iHwxdg0owYaAFwAHgAgAEAiAEAkgEAmAEAoAEBqgEHZ3dzLXdperABCsABAQ&sclient=psy-ab&ved=2ahUKEwiM2-_ZmY3uAhVNI6wKHQekCbIQ2wF6BAgIEAE 2 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #9 Posted January 9, 2021 Well my transmission is back together and everything is functioning perfectly. I reinstalled the old seal on the input shaft for now but ill look for an alternative to the SKF seal. BTW SKF is quality in my experience. Not sure why this particular seal is so bad but it is. I'd like to find one that resembles an original. The original has a thick metal top (1/32") and rubber sides. Nice design. The SKF is a traditional design but the metal sides are as strong as tin foil. This was a fun project and made easier by VinsRj on YouTube! Thanks Vin! 1 1 Share this post Link to post Share on other sites
jackhammer 550 #10 Posted June 12, 2025 (edited) Hey WheelhorseBob, years ago you made this post , but did you ever find a suitable replacement seal that you were looking for? I’ve got a 1990 312-8, looking for the drive seal and rear axles seals but having difficulty locating. Any help appreciated . Thanks, jackhammer Edited June 12, 2025 by jackhammer 1 Share this post Link to post Share on other sites
ebinmaine 77,549 #11 Posted June 12, 2025 8 hours ago, jackhammer said: Hey WheelhorseBob, years ago you made this post , but did you ever find a suitable replacement seal that you were looking for? I’ve got a 1990 312-8, looking for the drive seal and rear axles seals but having difficulty locating. Any help appreciated . Thanks, jackhammer Check the top of the Transmission section for a Pinned Thread about seals and bearings. You’ll find the numbers there. Plenty of parts availability. 1 Share this post Link to post Share on other sites
jackhammer 550 #12 Posted June 12, 2025 Thanks Eric , I’ll do that 1 Share this post Link to post Share on other sites
stevasaurus 23,627 #13 Posted June 12, 2025 Been awhile @jackhammer...how ya doing?? 1 Share this post Link to post Share on other sites
jackhammer 550 #14 Posted June 12, 2025 Hello Dino yes it’s been a while , see you’re still plugging along . I pop in once on a while just to see what guys are talking about about. Things ok up north for you? Darn two 312-8 tractors down at same time and grass doesn’t know when to slow down 1 Share this post Link to post Share on other sites
stevasaurus 23,627 #15 Posted June 13, 2025 Ya, things are OK here. Really miss some of the old faces that are now gone, and also the old shows we would go to. Share this post Link to post Share on other sites
