ebinmaine 79,116 #26 Posted January 4, 2021 40 minutes ago, c-series don said: 54” I have a plow at my house that was made up by Mr John @wallfish. I assume he combined two, 42-in plows. Measures about 60.5" across if I remember correctly. I've I've been mulling over putting that on Cinnamon horse for winter duty this year. Dennis get you some roller chain on the front of whatever and you'll wonder what you ever did with your life before they were there. They can be had off of the flea Bay for about $20 including an extra master link. Share this post Link to post Share on other sites
DennisThornton 4,773 #27 Posted January 4, 2021 (edited) 3 hours ago, ebinmaine said: I have a plow at my house that was made up by Mr John @wallfish. I assume he combined two, 42-in plows. Measures about 60.5" across if I remember correctly. I've I've been mulling over putting that on Cinnamon horse for winter duty this year. Dennis get you some roller chain on the front of whatever and you'll wonder what you ever did with your life before they were there. They can be had off of the flea Bay for about $20 including an extra master link. Eric I've had new roller chain in a box for years now, even before I saw John's invention and I still slide all over! Oh! You are suggesting that I actually install the chain? Part of my problem is that since joining this forum I now know more than I have time to implement! Terrible problem! If I quit buying tractors maybe I would have time to fix one! (Gads, please don't let the woman of the household know I said that!) What we say here stays here doesn't it? Edited January 5, 2021 by DennisThornton Eric! 1 4 Share this post Link to post Share on other sites
Maxwell-8 4,371 #28 Posted January 4, 2021 4 hours ago, ebinmaine said: Those Bolens weights are out there. In fact, that's what's on Trina's 867. They are heavy, sold rims with those one time. Share this post Link to post Share on other sites
ebinmaine 79,116 #29 Posted January 4, 2021 14 minutes ago, Maxwell-8 said: They are heavy, sold rims with those one time. 65 lbs EACH 1 Share this post Link to post Share on other sites
Maxwell-8 4,371 #30 Posted January 4, 2021 1 minute ago, ebinmaine said: 65 lbs EACH Yes, they could be around there indeed.. 1 Share this post Link to post Share on other sites
c-series don 11,963 #31 Posted January 4, 2021 (edited) 1 hour ago, DennisThornton said: Love the big blade! And the wheel weights! (No comment on the 4-links...) I've got some 48" blades but NO 54". But unless I were to add Wallfish's roller chains on the front I wouldn't be steering, the 54"s would be. Very nice! I’ve got the two links on the 417-A with two stage blower. All around I agree Dennis that the two links are better especially when it comes to the ride. Also pay no attention to my F-350 powerstroke with 8’ Fisher plow in the background! Plowing my driveway with that is no where near as fun as the snowblower! I use the truck for my snowplowing business. Edited January 4, 2021 by c-series don 3 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #32 Posted January 4, 2021 I did a 42" to 50" with my very first blade, then found a decent but bottom worn 54" then found myself a 56" that was originally made for WH ZTR mower. 1 2 Share this post Link to post Share on other sites
DennisThornton 4,773 #33 Posted January 4, 2021 25 minutes ago, c-series don said: I’ve got the two links on the 417-A with two stage blower. All around I agree Dennis that the two links are better especially when it comes to the ride. Also pay no attention to my F-350 powerstroke with 8’ Fisher plow in the background! Plowing my driveway with that is no where near as fun as the snowblower! I use the truck for my snowplowing business. I've used 2-links for so long that I'd forgotten why until I couldn't find my other 2-links and through on the only pair I could find, 4-links, then I bounced up and down for the rest of the day. They work! Half the time! Then bounce in-between links! Got to find my other 2-links or add links to these! 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #34 Posted January 4, 2021 3 minutes ago, WVHillbilly520H said: I did a 42" to 50" with my very first blade, then found a decent but bottom worn 54" then found myself a 56" that was originally made for WH ZTR mower. Very nice job! And works well without roller chain on the fronts? I've actually used my 48" to help me steer uphill out of an incline that I otherwise couldn't climb! Not so good trying to stay straight going down the driveway though. 1 Share this post Link to post Share on other sites
ebinmaine 79,116 #35 Posted January 5, 2021 39 minutes ago, DennisThornton said: works well without roller chain Just for the record Dennis. I have the same roller chain set-up on the front of Cinnamon that you do. Setting in a box in the shed. I do have a VERY heavy front end. With 110 lb of fluid up there I rarely have a serious issue steering. 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #36 Posted January 5, 2021 3 minutes ago, ebinmaine said: Just for the record Dennis. I have the same roller chain set-up on the front of Cinnamon that you do. Setting in a box in the shed. I do have a VERY heavy front end. With 110 lb of fluid up there I rarely have a serious issue steering. Pretty sure I know where my box of roller chain is. I really should do that soon. I have NO front wheel weights and I've never filled front tires even though we both know how important weight is. Share this post Link to post Share on other sites
ebinmaine 79,116 #37 Posted January 5, 2021 2 minutes ago, DennisThornton said: Pretty sure I know where my box of roller chain is. I really should do that soon. I have NO front wheel weights and I've never filled front tires even though we both know how important weight is. My fronts are oversized and have 5 gallons per tire. 55 lbs each. Plus the fact that there's more metal and rubber out there. All told the front is weighted down about 120 lbs. 1 Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #38 Posted January 5, 2021 1 hour ago, DennisThornton said: Very nice job! And works well without roller chain on the fronts? I've actually used my 48" to help me steer uphill out of an incline that I otherwise couldn't climb! Not so good trying to stay straight going down the driveway though. Sometimes it gets a bit sideways but lift the blade a touch and it straightens out and put it back down, what really helps now is 1) the 5 position angle quadrant (don't full angle) 15° instead of 30° in the heavy stuff 2) I'm running AGs on all 4 corners now and seem to have more lateral grip IMO. 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #39 Posted January 5, 2021 3 minutes ago, WVHillbilly520H said: Sometimes it gets a bit sideways but lift the blade a touch and it straightens out and put it back down, what really helps now is 1) the 5 position angle quadrant (don't full angle) 15° instead of 30° in the heavy stuff 2) I'm running AGs on all 4 corners now and seem to have more lateral grip IMO. All makes sense. I've got to lift mine from time to time. I have down pressure too and there's times I can't push full hard and still go straight. I don't foresee ags on the front for mine but I do intend to add roller chain. Thanks! 1 Share this post Link to post Share on other sites
bc.gold 3,406 #40 Posted January 5, 2021 7 hours ago, DennisThornton said: Well, if I can't figure out what to do can I reach out to "her"? I believe her has a proprietary operating system installed and you must know the secret encrypted password to logon. Share this post Link to post Share on other sites
DennisThornton 4,773 #41 Posted January 5, 2021 8 minutes ago, bcgold said: I believe her has a proprietary operating system installed and you must know the secret encrypted password to logon. I'd just ask Eric then. 2 Share this post Link to post Share on other sites
ebinmaine 79,116 #42 Posted January 5, 2021 11 minutes ago, DennisThornton said: I'd just ask Eric then. Nailed it. Share this post Link to post Share on other sites
DennisThornton 4,773 #43 Posted January 5, 2021 This might be a good use for some dirt tires. I have a mid-mount for an XI too! But I'd take a mid-mount for either a Sears/Roper, Bolens or a C-series WH. Mid-mount a good use for my tri-ribs and ags? By the way, for those new to Bolens tube frames, look at that front axle AND all that brown under the white grille is solid cast iron! It needs to be sturdy since the front attachments connect directly to the front axle! Beefy little GTs. 2 Share this post Link to post Share on other sites
DennisThornton 4,773 #44 Posted January 5, 2021 Got big AGs on my mind while looking for Bolens stuff and this caught my eye. Ain't this cute! I've got a rough Lawn Ranger... But no... 2 Share this post Link to post Share on other sites
ebinmaine 79,116 #45 Posted January 5, 2021 6 hours ago, DennisThornton said: Mid-mount a good use for my tri-ribs and ags? ABSOLUTELY 1 Share this post Link to post Share on other sites
cschannuth 3,821 #46 Posted January 5, 2021 I have some sort of rib front tire and Ags on all my tractors except one and they don’t do any damage to my yard. Plus all of my Ags are loaded. Most have at least one set of wheel weights installed. My C-161 Ags are loaded and have inside and outside weights because I push a 54 inch snow blade with it. I run them that way year around because I like the stability that it provides. I used to have chains for plowing but on my steep concrete drive, unless it was covered with ice, it didn’t provide any benefit. On my dad’s asphalt driveway, having chains was actually dangerous because it was so steep. It was like ice skates on ice. I say put them on one of your tractors and enjoy them. 4 1 Share this post Link to post Share on other sites
Pullstart 70,093 #47 Posted January 5, 2021 @c-series don I noticed you have a Pabst sign on your wall... 2 Share this post Link to post Share on other sites
c-series don 11,963 #48 Posted January 5, 2021 Actually I have two PBR signs 😂😀one lit one not! Who doesn’t like an ice cold PBR? 1 Share this post Link to post Share on other sites
DennisThornton 4,773 #49 Posted January 5, 2021 I found this site informative regarding tire chains. Different patterns all mounted on ags. https://www.tirechain.com/23X10.50X12.htm This set caught my eye. This is HD. I have a medium duty that I'm quite fond of. 1 Share this post Link to post Share on other sites
ebinmaine 79,116 #50 Posted January 6, 2021 3 hours ago, DennisThornton said: I found this site informative regarding tire chains. Different patterns all mounted on ags. https://www.tirechain.com/23X10.50X12.htm This set caught my eye. This is HD. I have a medium duty that I'm quite fond of. I don't know the grade of my chains. They sure do look like those.... Share this post Link to post Share on other sites
