DAP 0 #1 Posted December 12, 2020 Will a snow blade off of a B80 tractor fit a 416-8? Share this post Link to post Share on other sites
ebinmaine 79,710 #2 Posted December 12, 2020 If the one off the B-80 is a long frame plow then yes. Share this post Link to post Share on other sites
DAP 0 #3 Posted December 13, 2020 Do you have any measurements on the plow frame? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,360 #4 Posted December 13, 2020 I thought I could find the long frame measurement but no. I believe the B-80's with a 4-speed are medium frame tractors with 43-1/2" wheelbase. The B-80's with 8-speeds are long frame tractors with 45-1/2" wheelbase At the end of the day same plow is used on both. Garry 1 Share this post Link to post Share on other sites
ebinmaine 79,710 #5 Posted December 13, 2020 2 hours ago, DAP said: Do you have any measurements on the plow frame? It should be compatible. If the plow frame has a section towards the transmission end that is parallel then it's a long frame plow. Short frame plows look like a triangle. Share this post Link to post Share on other sites
DAP 0 #6 Posted December 15, 2020 The plow seems to hook up, but the lever that shifts the plow to angle, the foot pad on the tractor is in the way. I don't if welding the bracket forward is the answer. Also the lift mechanism is a little different Share this post Link to post Share on other sites
ebinmaine 79,710 #7 Posted December 15, 2020 3 hours ago, DAP said: The plow seems to hook up, but the lever that shifts the plow to angle, the foot pad on the tractor is in the way. I don't if welding the bracket forward is the answer. Also the lift mechanism is a little different I can get a picture or two of how it's hooked up on my Cinnamon Horse which is a c160. There are two or three different ways to hook up the lift mechanism. At our acreage we both use a solid link so we can have down pressure. That's a solid metal bar about 11" long. Share this post Link to post Share on other sites
1990Onan520-H 15 #8 Posted December 15, 2020 (edited) 3 hours ago, DAP said: The plow seems to hook up, but the lever that shifts the plow to angle, the foot pad on the tractor is in the way. I don't if welding the bracket forward is the answer. Also the lift mechanism is a little different Not sure if I have the same plow, but when hooking mine to my 416 I had to put two bends in my handle (straight handle) to clear my muffler, and there is a notch in the handle to clear the foot rest. Then used an old coat hanger to connect it to the release mechanism and added a few eyelets to hold it in place. Hope this helps. Trying to add a pic but for some reason can't at the moment. Could be my work computer blocking things. I'll keep trynig. Edited December 15, 2020 by 1990Onan520-H Share this post Link to post Share on other sites
DAP 0 #9 Posted December 16, 2020 Thanks. I will take a look at this. Share this post Link to post Share on other sites
