seven 202 #1 Posted December 7, 2020 Have this old cast iron 7 hp briggs model 19d . Put a new carb on it cause I couldn't get the old one to stop leaking out the bottom. It's what you call a upflow carb pretty common back in the day? Anyway go to start it up runs and starts perfect but turn throttle up and it takes off . And won't go back down with control only if you like force it down manually. Everything is the same as it was on original carb as far as linkages. Share this post Link to post Share on other sites
WHNJ701 4,166 #2 Posted December 7, 2020 Hate to ask... Is it one of china's finest after market carbs? A 2 part flo jet is very easy to rebuild Share this post Link to post Share on other sites
seven 202 #3 Posted December 7, 2020 Yes it's chinas finest . I tried the new emulsion tube on it but couldn't get it to seat kept leaking so I gave up on it. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,737 #4 Posted December 7, 2020 Have had good luck applying Teflon paste pipe thread sealer on the tapered seat with a toothpick. Think it is a Permatex product. Garry Share this post Link to post Share on other sites
seven 202 #5 Posted December 8, 2020 Ok maybe I will try that I just am having a hard time with this one it may be that they sent me the wrong carb .idk I would like to find a good oem rebuild kit also. I'm on one carb kit one new carb and back to square one oh well. Share this post Link to post Share on other sites
WHNJ701 4,166 #6 Posted December 8, 2020 Look for old oem carbs at shows/sales/online etc... For parts and rebuild. One thing about the 2 parts is they tend to warp. Spray paint the ends black and and sand them on piece of glass Share this post Link to post Share on other sites
seven 202 #7 Posted December 8, 2020 50 minutes ago, gwest_ca said: Have had good luck applying Teflon pipe thread sealer on the tapered seat with a toothpick. Think it is a Permatex product. Garry Share this post Link to post Share on other sites
seven 202 #8 Posted December 8, 2020 Is this the area I would apply the teflon Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,737 #9 Posted December 8, 2020 Yes. It seals below the fuel level in the bowl. The holes in the tube are above the fuel level. I never applied sealer to the threads because installing it could allow some sealer to come off and interfere with the adjustment needle/jet I should have called the sealer a paste. Garry Share this post Link to post Share on other sites
seven 202 #10 Posted December 8, 2020 Ok thank you I will look at getting some teflon at auto parts store will let you know how it goes ☺️ Share this post Link to post Share on other sites
seven 202 #11 Posted December 8, 2020 1 hour ago, gwest_ca said: Yes. It seals below the fuel level in the bowl. The holes in the tube are above the fuel level. I never applied sealer to the threads because installing it could allow some sealer to come off and interfere with the adjustment needle/jet I should have called the sealer a paste. Garry Well I've come to the conclusion that my float needle (on original carb) was not seating like it should so that is fixed along with a tiny bit of teflon on tapered tube . Will see tomorrow if it all works out ☺️ 1 1 Share this post Link to post Share on other sites
seven 202 #12 Posted December 9, 2020 21 hours ago, seven said: Well I've come to the conclusion that my float needle (on original carb) was not seating like it should so that is fixed along with a tiny bit of teflon on tapered tube . Will see tomorrow if it all works out ☺️ Up and running like it should thxs 1 Share this post Link to post Share on other sites
