AHS 1,597 #1 Posted December 7, 2020 My guess is yes! Also, which hole (On the tractor) does a long link go into? I have the picture (somewheres!) of all the holes of the tractor and what they are meant for.. the snowblower, the plow, etc. 1 Share this post Link to post Share on other sites
8ntruck 8,626 #2 Posted December 7, 2020 If you have the model number for the plow, there is probably a manual in the manual section of this forum. There is also an attachment interchange list as a sticky post in the implement section in the forum that could tell you if the plow will fit your tractor. Good luck. 1 Share this post Link to post Share on other sites
ebinmaine 77,541 #3 Posted December 8, 2020 Any LONG FRAME plow from 67 up will fit a B Series built from '74-'77. Horizontal engines. 2 hours ago, AHS said: which hole (On the tractor) does a long link go into? The rock shaft that's connected to the up/down handle has 2 arms inside the steering wheel tower. One of them points mostly down and is used to create back/forth movement. The one you want is mostly horizontal. It creates up/down motion. The 11" solid link goes in the outermost hole in that arm. No I didn't get a pic but here's a dog under a blanket: 1 4 Share this post Link to post Share on other sites
AHS 1,597 #4 Posted December 8, 2020 A dog? A Wheelhorse dog? A dog named Raider? 😀 2 1 Share this post Link to post Share on other sites
ebinmaine 77,541 #5 Posted December 8, 2020 5 minutes ago, AHS said: A dog? A Wheelhorse dog? A dog named Raider? 😀 Definitely a Wheelhorse dog. Named Meeha / Mirror. Right @pullstart? 1 1 Share this post Link to post Share on other sites
Pullstart 68,981 #6 Posted December 8, 2020 DRn tootin’. 3 Share this post Link to post Share on other sites
