ebinmaine 81,024 #1 Posted December 4, 2020 I know the length is going to vary based on what weights you're using but are they all 1/2" carriage bolts? I need to pick some up on the way home... 3 Share this post Link to post Share on other sites
rmaynard 17,628 #2 Posted December 4, 2020 The square hole in the rim is the correct size for the shoulder of a 1/2" carriage bolt. 3 1 Share this post Link to post Share on other sites
lynnmor 9,058 #3 Posted December 4, 2020 If you don't care about having the standard carriage bolt head, just buy 1/2-13 all thread and cut to length. You will need 3 hex nuts, 2 lock washers and 1 to 3 flat washers for each bolt. 2 Share this post Link to post Share on other sites
WHNJ701 4,173 #4 Posted December 4, 2020 Don't forget the never seize! 3 Share this post Link to post Share on other sites
Pullstart 71,479 #5 Posted December 4, 2020 1 hour ago, jabelman said: Don't forget the never seize! Keepthat stuff away from @Achto unless you want to wear it home... 5 Share this post Link to post Share on other sites
Achto 32,869 #6 Posted December 4, 2020 18 minutes ago, pullstart said: Keepthat stuff away from @Achto unless you want to wear it home... I have no idea what your talking about. 3 Share this post Link to post Share on other sites
ebinmaine 81,024 #7 Posted December 4, 2020 3 hours ago, pullstart said: Keepthat stuff away from @Achto unless you want to wear it home... 3 hours ago, Achto said: I have no idea what your talking about. On the plus side you'd be a nice silver shade like the character Colossus.... 1 1 1 Share this post Link to post Share on other sites
WHX?? 58,310 #8 Posted December 5, 2020 4 hours ago, pullstart said: Keepthat stuff away from @Achto unless you want to wear it home... Now Kev you know he was just being a bro and trying to keep your suck point adjuster from brown welding. He just got the jitters ...had too much blood in his alcohol system me thinks......good thing I didn't hand him the spray can of the stuff! 2 Share this post Link to post Share on other sites
RandyLittrell 3,946 #9 Posted December 5, 2020 8 hours ago, ebinmaine said: I know the length is going to vary based on what weights you're using but are they all 1/2" carriage bolts? I need to pick some up on the way home... It's more work, but I really like putting the carriage bolt head on the outside! Keeps your shins and anything else you rub up against from getting tore up!! Randy 2 Share this post Link to post Share on other sites
ebinmaine 81,024 #10 Posted December 5, 2020 1 minute ago, RandyLittrell said: It's more work, but I really like putting the carriage bolt head on the outside! Keeps your shins and anything else you rub up against from getting tore up!! Randy I bought 6" bolts and I know I only need 4 or 5. I "cap" the end of the bolt with a second nyloc nut set right at the end of the bolt. I have used closed end nuts but found they would break through the cap and I wouldn't notice until I ripped my pants.... Or leg. 1 Share this post Link to post Share on other sites
JohnD 145 #11 Posted December 6, 2020 My C-175 has 9" long bolts and they end flush with the nuts at the outer edge of the weight. Perfect! 1 Share this post Link to post Share on other sites
ebinmaine 81,024 #12 Posted December 6, 2020 Just now, JohnD said: My C-175 has 9" long bolts and they end flush with the nuts at the outer edge of the weight. Perfect! That'll be about right with the second set of weights on. Share this post Link to post Share on other sites
JohnD 145 #13 Posted December 6, 2020 1 hour ago, ebinmaine said: That'll be about right with the second set of weights on. It's a single weight. A different single weight, I guess. 2 Share this post Link to post Share on other sites
Jeff-C175 7,211 #14 Posted December 9, 2020 On 12/5/2020 at 8:46 PM, JohnD said: My C-175 has 9" long bolts and they end flush with the nuts at the outer edge of the weight. Perfect! I think it must depend entirely on the exact weights used. The ones I found on the side of the road took 7" long 1/2" bolts but they are not as thick as the ones in JohnD's photo. Mine snug into the wheel much farther, I guess 2" less 'stick out'! 1 Share this post Link to post Share on other sites
ebinmaine 81,024 #15 Posted December 9, 2020 15 minutes ago, Jeff-C175 said: must depend entirely on the exact weights used Definitely correct. the ones I was asking about in the original post I found out when I got home they actually sit on the outside rim and do not sink in at all so I have to go back and get some longer bolts. Share this post Link to post Share on other sites
JohnD 145 #16 Posted December 10, 2020 On 12/4/2020 at 12:03 PM, ebinmaine said: I know the length is going to vary based on what weights you're using... Share this post Link to post Share on other sites
