oliver2-44 11,758 #1 Posted November 29, 2020 (edited) I was looking for some carb information and came across these. Exhaust Stud Installation Kohler Exhaust Stud installation Kohler engines have an 'interference thread" on one side of the exhaust stud. This larger thread is designed to be inserted into the head and stay in place allowing for easy assembly and removal of the exhaust system. A "Dot" is used on one end of the stud to indicate the small thread side. When installed into the cylinder head the "Dot" should be visible. kohler Throttle_Choke_Shaft_Guide.pdf Edited November 29, 2020 by oliver2-44 3 1 Share this post Link to post Share on other sites
WHNJ701 4,173 #2 Posted November 29, 2020 Good to know, I need to track them down for the k160 1 Share this post Link to post Share on other sites
oliver2-44 11,758 #3 Posted November 29, 2020 @jabelman if you find some Kohler studs, lets us know where. I need some as well! 2 Share this post Link to post Share on other sites
ebinmaine 80,783 #4 Posted November 29, 2020 4 hours ago, jabelman said: track them down Is that something McMaster Carr, K. L. Jack, Bolt Depot would have? Share this post Link to post Share on other sites
peter lena 10,077 #5 Posted November 29, 2020 take the time to use a FINISH TAP on those threads , along with lubricating oil and a magnet , to clean out the holes . never seize would also secure your work , pete 1 Share this post Link to post Share on other sites
WHNJ701 4,173 #6 Posted November 29, 2020 10 hours ago, oliver2-44 said: @jabelman if you find some Kohler studs, lets us know where. I need some as well! Kohler Part #220133 1/4-20 & 1 7/8" long Kohler book says use a brass nut too I just bought a 4 pack on ebay. I swore i had bought these before! Been piecing this thing back together for 3 years now, I am probably going to have 2 of everything by the time I am done 1 Share this post Link to post Share on other sites
ebinmaine 80,783 #7 Posted November 29, 2020 8 minutes ago, jabelman said: I swore i had bought these before! Been piecing this thing back together for 3 years now, I am probably going to have 2 of everything by the time I am done I understand that all too well. At least you know you have spares of hidden parts for future use. Share this post Link to post Share on other sites
R Scheer 524 #8 Posted November 29, 2020 2 hours ago, jabelman said: Kohler Part #220133 1/4-20 & 1 7/8" long Kohler book says use a brass nut too I just bought a 4 pack on ebay. I swore i had bought these before! Been piecing this thing back together for 3 years now, I am probably going to have 2 of everything by the time I am done You've got a excuse to get another tractor now. Wouldn't want those extra parts to go to waste... Share this post Link to post Share on other sites
sqrlgtr 4,022 #9 Posted November 29, 2020 3 hours ago, jabelman said: Kohler Part #220133 1/4-20 & 1 7/8" long Kohler book says use a brass nut too I just bought a 4 pack on ebay. I swore i had bought these before! Been piecing this thing back together for 3 years now, I am probably going to have 2 of everything by the time I am done 2 or 3 of everything ,but that one piece or two to finish Share this post Link to post Share on other sites
oliver2-44 11,758 #10 Posted November 30, 2020 19 hours ago, ebinmaine said: Is that something McMaster Carr, K. L. Jack, Bolt Depot would have? EB I'm guessing, but I suspect this is a special Kohler item. I previously had taken an exhaust stud I have to Ace and the studs in their Hillman drawers did not match the one side with the Kohle " larger interferance thread" 1 Share this post Link to post Share on other sites
Mickwhitt 5,259 #11 Posted November 30, 2020 It would be easy to make a thread slightly oversize using a split die. I made my own brass nuts for the new exhaust flange on my kohler. Im having fun with mine splitting the flywheel key down the middle and screwing the timing up. Looks like it may be a while before I get her running again. Share this post Link to post Share on other sites
