Mows4three 833 #1 Posted November 15, 2020 It's nine o'clock on a Saturday The regular crowd shuffles in............ This Whatz It is open to everyone except Eric in Maine. Not that he isn’t smart enough, he is. And not that he isn’t worthy, he certainly is. But, he already knows what in tarnation this gizmo is used for. This item is 18” in overall length and approximately 3 3/4” in diameter at its widest point. The rivets and bolts are all loose enough to allow the two pieces on the side to move. It is blacksmith made and has no makers mark on it. Any guesses? Anyone know what it’s intended purpose is? Cheers! Dave 1 Share this post Link to post Share on other sites
troutbum70 858 #2 Posted November 15, 2020 I think I know but is missing a couple important parts. Familly used one much larger many years ago along with a team of horses. Share this post Link to post Share on other sites
Mows4three 833 #3 Posted November 15, 2020 From what I know about these, this is a complete tool. I don’t think it was ever used with horses. Dave Share this post Link to post Share on other sites
Pullstart 71,329 #4 Posted November 15, 2020 Chicken head holder for slaughter? 4 Share this post Link to post Share on other sites
troutbum70 858 #5 Posted November 15, 2020 Okay probably not same thing, but looks very similar. Share this post Link to post Share on other sites
Mows4three 833 #6 Posted November 15, 2020 Not associated with chicken or poultry farming in any way. Dave Share this post Link to post Share on other sites
Handy Don 17,495 #7 Posted November 15, 2020 I'd guess something for cleaning the bore of a well. Used with a rope. Similar to cleaning a chimney. Share this post Link to post Share on other sites
Mows4three 833 #8 Posted November 15, 2020 You are headed in the right direction with a well. Close, but you’ve not yet hit the mark. Dave Share this post Link to post Share on other sites
JAinVA 4,638 #9 Posted November 15, 2020 (edited) Is this a tool for retrieving a well pipe? Drop it down pull it up. Edited November 15, 2020 by JAinVA 2 Share this post Link to post Share on other sites
8ntruck 9,313 #10 Posted November 15, 2020 Or maybe for grabbing and loading a new length of pipe into the well? 2 Share this post Link to post Share on other sites
Pullstart 71,329 #11 Posted November 15, 2020 For pulling a well point? Share this post Link to post Share on other sites
Mows4three 833 #12 Posted November 15, 2020 9 hours ago, JAinVA said: Is this a tool for retrieving a well pipe? Drop it down pull it up. Yep. You got it Jim! It’s called a fishing tool. It was usually attached to the light weight sand line on a drilling rig or on a clean-out truck winch. The bell shaped end of the fishing tool guides the device over a lost piece of pipe. The two grippers in the pipe hold on to the pipe as you gently back haul the pipe out of the hole. This was not an exact science and several attempts might be made until the pipe was caught by the fishing tool with sufficient “grippage” to pull it out of the bore hole. I picked it it up because these are not very common due to their purpose built (blacksmith made) nature, AND our Latrobe Sportsmen’s Association has a broken off 2” pipe section and a foot valve, about 25’ long, 60’ down our well. I’m hoping this it the ticket to retrieving it. May the spirits of John Wayne and Red Adair be with me when we try to haul out this piece of pipe! Cheers! Dave 3 2 Share this post Link to post Share on other sites
Stormin 9,988 #13 Posted November 15, 2020 Good luck. You realise we will want a report and PHOTO'S of it in use. 2 Share this post Link to post Share on other sites
tom2p 2,396 #14 Posted November 17, 2020 On 11/15/2020 at 9:44 AM, Mows4three said: Yep. You got it Jim! It’s called a fishing tool. It was usually attached to the light weight sand line on a drilling rig or on a clean-out truck winch. The bell shaped end of the fishing tool guides the device over a lost piece of pipe. The two grippers in the pipe hold on to the pipe as you gently back haul the pipe out of the hole. This was not an exact science and several attempts might be made until the pipe was caught by the fishing tool with sufficient “grippage” to pull it out of the bore hole. I picked it it up because these are not very common due to their purpose built (blacksmith made) nature, AND our Latrobe Sportsmen’s Association has a broken off 2” pipe section and a foot valve, about 25’ long, 60’ down our well. I’m hoping this it the ticket to retrieving it. May the spirits of John Wayne and Red Adair be with me when we try to haul out this piece of pipe! Cheers! Dave fairly certain I saw Arnold Palmer use that tool to retrieve golf balls from a deep water hazard 2 Share this post Link to post Share on other sites
