23 Reo 229 #1 Posted November 14, 2020 Has anyone made an attachment that would hook up a walk behind leaf blower to a Wheel Horse? Share this post Link to post Share on other sites
953 nut 58,191 #2 Posted November 14, 2020 Not a walk behind but I mounted a blower from a heat/AC unit to a mule drive. 3 7 Share this post Link to post Share on other sites
ebinmaine 70,963 #3 Posted November 15, 2020 16 hours ago, 953 nut said: Not a walk behind but I mounted a blower from a heat/AC unit to a mule drive. Can you rotate that pipe or is it a one way air flow? Share this post Link to post Share on other sites
WHNJ701 4,165 #4 Posted November 15, 2020 Just driving home this morning I saw someone with a kubota tractor and front bucket,. He had one those walk behind blowers ratcheted in the bucket. Looked like it was working Share this post Link to post Share on other sites
8ntruck 7,439 #5 Posted November 15, 2020 On 11/14/2020 at 5:49 PM, 953 nut said: Not a walk behind but I mounted a blower from a heat/AC unit to a mule drive. Adding a reducer section to the outlet end of the elbow would increase the air velocity out of the blower. Share this post Link to post Share on other sites
953 nut 58,191 #6 Posted November 16, 2020 7 hours ago, ebinmaine said: Can you rotate that pipe or is it a one way air flow? I could if needed but I make one pass up the driveway and another pass down and the driveway is cleared. 6 minutes ago, 8ntruck said: Adding a reducer section to the outlet end of the elbow would increase the air velocity out of the blower. That was my first go round bup the added volume far outperforms greater velocity. 2 Share this post Link to post Share on other sites
cschannuth 3,817 #7 Posted November 16, 2020 On 11/14/2020 at 5:49 PM, 953 nut said: Not a walk behind but I mounted a blower from a heat/AC unit to a mule drive. Is it just attached to the front hitch? I have the blower but need to fab the mount. Thanks Share this post Link to post Share on other sites
953 nut 58,191 #8 Posted November 16, 2020 6 minutes ago, cschannuth said: Is it just attached to the front hitch? I have the blower but need to fab the mount. Thanks I welded the frame that holds the blower to an old mule drive. 1 1 Share this post Link to post Share on other sites
formariz 11,994 #9 Posted November 16, 2020 Here is my favorite implement in use. https://youtu.be/yA-jVznlmN0 4 Share this post Link to post Share on other sites
c-series don 9,468 #10 Posted November 17, 2020 When I was a kid I remember my step grandpa (the guy who got me hooked on Wheel Horses) made up some simple brackets and hung a Little Wonder 8hp walk behind blower on his snowplow/dozer blade. He had it on his C-161 Twin Automatic which I now have resting in my basement. I’m not sure how hard it was to steer, but I remember he could angle the blade left and right to direct the airflow. 4 1 Share this post Link to post Share on other sites
WHX?? 50,821 #11 Posted November 17, 2020 I have a behind with the classic Briggs 5 hp on it and was figuring out a way to strap it to a horse for extended seat time. SWMBO put an end to it when she said she needed her fitbit steps whatever in the he double hockey sticks that means! Oh well my drive is not that long but seat time is seat time! 2 Share this post Link to post Share on other sites
