Oldskool 6,663 #51 Posted February 10, 2021 Here is what I have so far. 3 1 Share this post Link to post Share on other sites
Oldskool 6,663 #52 Posted February 10, 2021 @gt14rider I think the only pieces to make now are a few pins and the mount with the rubber that attaches to the hitch. I dont have any measurements for that do you? I have 2 of the 3 pieces made. Share this post Link to post Share on other sites
gt14rider 944 #53 Posted February 11, 2021 I don't have that part. Will need to make one myself. Was going to use a chunk of mud flap for the rubber piece. You can probably stop at a truck shop and see if thay have any old one laying around. 1 Share this post Link to post Share on other sites
gt14rider 944 #54 Posted February 11, 2021 Oh yeah, nice work 1 Share this post Link to post Share on other sites
Oldskool 6,663 #55 Posted February 11, 2021 1 minute ago, gt14rider said: I don't have that part. Will need to make one myself. Was going to use a chunk of mud flap for the rubber piece. You can probably stop at a truck shop and see if thay have any old one laying around. Ok I will wing it a bit. I was thinking a mud flap too. Something with nylon cording in it. I might be able to snag a piece at the local junkyard. It's closer to me. A couple of belts, pulleys, and pins and I'm up and going. Thanks again you have been a huge help. I may still need some tech help on installation. Share this post Link to post Share on other sites
Oldskool 6,663 #56 Posted February 12, 2021 @gt14rider I cant seem to be able to source the 2.5" idler anywhere. Any thought on acquiring one or could a bit larger one be used? Share this post Link to post Share on other sites
gt14rider 944 #57 Posted February 12, 2021 It is a idler pully,so you should be able too. As long as you have clearance? Might be able to find something at tractor supply. Anyone else have a pulley supplier? Share this post Link to post Share on other sites
Oldskool 6,663 #58 Posted February 12, 2021 Just now, gt14rider said: It is a idler pully,so you should be able too. As long as you have clearance? Might be able to find something at tractor supply. Anyone else have a pulley supplier? I wont know till its on if I have room for a large idler. I looked at Tractor supply. McMaster Carr. Motion industries, Napa Surplus Center along with alot of other Google generated results. 3 or 3.5 was the smallest with a 1/2 bore. Share this post Link to post Share on other sites
gt14rider 944 #59 Posted February 12, 2021 The pulley should be in the front so should have clearance, Share this post Link to post Share on other sites
Oldskool 6,663 #60 Posted February 12, 2021 Just now, gt14rider said: The pulley should be in the front so should have clearance, Oh ok. That's good. Thanks. Is there a second hole in that belt gaurd? It looks like there is in this pic. Share this post Link to post Share on other sites
ebinmaine 72,451 #61 Posted February 12, 2021 Mike what exactly are you looking for? I'll check my parts boxes from the auction. 1 Share this post Link to post Share on other sites
gt14rider 944 #62 Posted February 12, 2021 Chain (U) hooks to s hook then to frame . Should have plenty of room Share this post Link to post Share on other sites
Oldskool 6,663 #63 Posted February 12, 2021 1 hour ago, ebinmaine said: Mike what exactly are you looking for? I'll check my parts boxes from the auction. A 2.5" 1/2 bore v grooved idler with integrated bearing. 1 Share this post Link to post Share on other sites
Oldskool 6,663 #64 Posted February 12, 2021 1 hour ago, gt14rider said: Chain (U) hooks to s hook then to frame . Should have plenty of room Thats the tension on that belt? Huh. Is there a spring Im not seeing? Share this post Link to post Share on other sites
gt14rider 944 #65 Posted February 12, 2021 (edited) I have not got this far, have not mounted mine yet. But yes, maybe a spring, or eye bolt? Edited February 12, 2021 by gt14rider 1 Share this post Link to post Share on other sites
ebinmaine 72,451 #66 Posted February 12, 2021 1 hour ago, Oldskool said: A 2.5" 1/2 bore v grooved idler with integrated bearing. I've put that in my to-do for tomorrow 1 Share this post Link to post Share on other sites
gt14rider 944 #67 Posted February 13, 2021 Pic of belt tension, looks like parts cam in (L) parts bag Share this post Link to post Share on other sites
Oldskool 6,663 #68 Posted February 13, 2021 I have the mower under the tractor now. I hope to mount it this weekend 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,453 #69 Posted February 13, 2021 Have room for a 3" pulley? This is a Stens dealer in Canada. Sometimes the numbers are different in the US. https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=639 Garry 1 Share this post Link to post Share on other sites
Oldskool 6,663 #70 Posted February 13, 2021 15 minutes ago, gwest_ca said: Have room for a 3" pulley? This is a Stens dealer in Canada. Sometimes the numbers are different in the US. https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=639 Garry It's looking like I do. Thanks for the link Share this post Link to post Share on other sites
gt14rider 944 #71 Posted August 14, 2021 Hay oldschool, did you ever get the sickle bar working? And how about some pics. 1 Share this post Link to post Share on other sites
Oldskool 6,663 #72 Posted August 14, 2021 33 minutes ago, gt14rider said: Hay oldschool, did you ever get the sickle bar working? And how about some pics. Not as of yet. I do have everything all in one spot though. Everything but the belts. I just have to commit the GT to just a mowing tractor. Coming soon though. I let our field grow tall for our first hey harvest. As soon as its functioning I will definitely update. 1 2 Share this post Link to post Share on other sites
Oldskool 6,663 #73 Posted October 2, 2021 I think it's happening guys. It's been a while, but not stopping till I'm mowing. 1 1 Share this post Link to post Share on other sites
Oldskool 6,663 #74 Posted October 3, 2021 It's on. It's working. Some fine tuning and a sharpening and it should be good to go. 20211003_152617.mp4 3 Share this post Link to post Share on other sites
