Trex6942 1 #1 Posted November 11, 2020 I just bought this tractor and im looking to try to find a either a plow or a snow blower, Im not sure what im supposed to be looking for as far as the plow or snow blower ,its a 1997 Toro Wheel Horse 269H , if anyone has any information on the plow or blower please help, thank you. Share this post Link to post Share on other sites
ebinmaine 74,655 #2 Posted November 11, 2020 @gwest_ca could help with the numbers to look for. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,755 #3 Posted November 11, 2020 1994-1998 model 79252 48" dozer blade will fit and 2000-2003 model 79253 will fit Tire chains and wheel weights recommended. https://www.wheelhorseforum.com/search/?&q=79252&type=downloads_file&search_and_or=or&sortby=relevancy 1993-1996 model 79251 will also fit with adapter kit https://www.wheelhorseforum.com/search/?&q=79251&type=downloads_file&search_and_or=or&sortby=relevancy 1996-2005 model 79263 42" snowthrower will fit as well as 79261, 79262 will fit; requires Adapter Kit 93-7625. Tire chains and wheel weights recommended. https://www.wheelhorseforum.com/search/?&q=79263&type=downloads_file&search_and_or=or&sortby=relevancy https://www.wheelhorseforum.com/search/?&q=79262&type=downloads_file&search_and_or=or&sortby=relevancy https://www.wheelhorseforum.com/search/?&q=79261&type=downloads_file&search_and_or=or&sortby=relevancy Familiarize yourself with how they hook up using the operator manuals and the illustrated parts lists for all the loose pieces to complete the installation. When the units are off the tractor loose pieces often get lost and can be difficult to replace to make it work. Garry 1 Share this post Link to post Share on other sites
Trex6942 1 #4 Posted November 13, 2020 thank you for all your help , this is great , now i just have to be lucky enough to find one. Share this post Link to post Share on other sites
ebinmaine 74,655 #5 Posted November 13, 2020 3 hours ago, Trex6942 said: thank you for all your help , this is great , now i just have to be lucky enough to find one. Place an ad in our classified. Watch CL. FB marketplace. You're in a good area that's busy so that'll help. Folks like @Stepney @wallfish @Sparky may have advice there too. They're in Maine, Massachusetts, and CT respectively. If you have welding as a skill you may be able to modify one. Good luck! 1 Share this post Link to post Share on other sites
Trex6942 1 #6 Posted November 13, 2020 thank you I will check those out Share this post Link to post Share on other sites
Stepney 2,354 #7 Posted November 13, 2020 My yard plow is Ex. 26xx series actually. Its fairly similar to a classic GT plow with the exception of an offset angle lever and a slightly different lifting arrangement that mounts toward the front. If I had any of the running gear I could help you there but its long gone as I use it on a '67 model. All the same .. dont see why one couldn't simply modify an older GT generic long frame plow to mimic what my plow is. Ill have to find some pictures. This topic has come up before. 1 1 Share this post Link to post Share on other sites
Trex6942 1 #8 Posted December 10, 2020 what model plow should i be looking for my toro wheelhorse 269H 1997 ? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,755 #9 Posted December 13, 2020 Model number 79252 Garry Share this post Link to post Share on other sites
