scWHhauler 96 #1 Posted November 5, 2020 Hay all got some new tires and wheel studs for the landing gear 😀On the 141. What do think should I leave the wheels as they are that matches the patina or sand blast them and paint. Also where can I get the tie rods that have the heim joints. 1 Share this post Link to post Share on other sites
mr biggs 187 #2 Posted November 5, 2020 They look a little smaller 🕵️♀️I'm the exact opposite go bigger or go home !! but something new for the old girl is always good thing , 👍 5 1 Share this post Link to post Share on other sites
Sparky-(Admin) 26,694 #3 Posted November 5, 2020 Me personally....I would paint the rims almond/linen beige 2 1 Share this post Link to post Share on other sites
oldredrider 2,554 #5 Posted November 5, 2020 You have the solid rear wheels. Paint them up and show em off. 2 Share this post Link to post Share on other sites
ebinmaine 81,156 #6 Posted November 5, 2020 12 minutes ago, Sparky said: Me personally....I would paint the rims almond/linen beige 6 minutes ago, 953 nut said: Tie rods with the heim joints are a homemade thing. You can get the appropriate rod ends from McMaster-Carr. Share this post Link to post Share on other sites
ohiofarmer 3,529 #7 Posted November 5, 2020 Those wheels would be easy to paint because of being solid. first, jack up the tractor and use the engine to spin the wheel. Sand her down starting with 100 grit or so, spot prime with rustoleum red primer. Let the air out of the tire and force those super thin grocery bags between the rim and the tire. Now the fun begins. Use the engine again to spin the wheel and spray on a coat of primer [sanding optional] , and then apply paint. The solid wheel makes it easy because no spray is gonna get through. I spin paint all my wheels and it is super fast and easy. I just use a transmission/wheel/tire from a MTD piece of junk stood on its side and comfortably paint while standing 2 1 Share this post Link to post Share on other sites
peter lena 10,109 #8 Posted November 5, 2020 SCWHauler, what you want is called a female /stud heim joint , to make up the tie rod ends , https://www.amazon.com/Steel-Inch-Female-Heim-Joint/dp/B075FG4PMG, there is just abbot every variation here . I personally make up mine using 3/8 x 24 steel thread rod , you can replace with exact or make up what you like , just measure to original overall size. I use both types , the stud on the wheel end and the bolt thru on the horizontal center point, never had a problem or failure with these ,with years of service. once you start using heim joints , you might even think of putting one on the end of your PTO lever rod forward end , very smooth easy operation . just me , pete Share this post Link to post Share on other sites
Lee1977 7,809 #9 Posted November 5, 2020 2 hours ago, ebinmaine said: Tie rods with the heim joints are a homemade thing. You can get the appropriate rod ends from McMaster-Carr. I have bought three sets of heims joints from Speedway Motors. They have a good selection. 1 Share this post Link to post Share on other sites
scWHhauler 96 #10 Posted November 6, 2020 Hay BIG thanks to pete and lee for the heads up on the tie rods 1 Share this post Link to post Share on other sites
