Chrishar 974 #1 Posted November 4, 2020 What is the difference between the 702 and the 502 beside the motor any information would help thanks Share this post Link to post Share on other sites
Pullstart 68,877 #2 Posted November 4, 2020 I believe that’s pretty much it! The 702 I believe was starter / generator, the 502 is @pullstart 1 Share this post Link to post Share on other sites
ri702bill 11,253 #3 Posted November 4, 2020 Chris: As Pullstart stated, they are basically the same tractor. Some differences I have seen between my 502 parts tractor and my 702's - the 502 came with a metal open top "Toolbox" the size of the 702 battery - mounted the same as the battery. The 502 had a 2 piece gas tank, similar to the 1963 753 and my 1964 854 - the 702's have the one piece tank with the removable cast iron dash panel. The 702's came with a 2 inch Ammeter in the center of the dash - the 502 had a 2 inch block off plate that mounted the on-off toggle switch instead. Choke and throttle controls are the same - the 702's have a 2 prong key switch (power to the coil) along with the starter button mounted on the hood stand - the 502 had neither. Same hood stand. Bill 1 Share this post Link to post Share on other sites
