WheelhorseBob 1,550 #1 Posted October 31, 2020 (edited) Ok guys, I recently picked up a NOS D-series front axle assembly. I consists of the axle, 1” spindles and rims with bearings. If I were to put a 520 swept front axle in my 161, I could use the spindles and rims to make the heaviest C series front evah! Thoughts and has anyone done this? If this sounds foolish say so. I’m sure a D-series enthusiast would covet this front end. Edited October 31, 2020 by WheelhorseBob 2 Share this post Link to post Share on other sites
oliver2-44 11,504 #2 Posted October 31, 2020 (edited) @WheelhorseBob it almost been half an hour, have you got it finished yet. Edited October 31, 2020 by oliver2-44 2 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #3 Posted November 1, 2020 Not yet my friend. But I’ll get on it! 1 Share this post Link to post Share on other sites
pfrederi 20,627 #4 Posted November 1, 2020 There may be an alignment issue for the tie rods. The D series spindles have a bent tie rod attachment plate, 520s are straight. 1 1 Share this post Link to post Share on other sites
WheelhorseBob 1,550 #5 Posted November 1, 2020 4 hours ago, pfrederi said: There may be an alignment issue for the tie rods. The D series spindles have a bent tie rod attachment plate, 520s are straight. I had considered that. I would make custom length tie rods anyhow. And the tie rod plate on the C161 Is shorter because the stock 3/4" spindles have the upswept tie rod mounts already. Share this post Link to post Share on other sites
c-series don 11,953 #6 Posted November 1, 2020 I think you might be better off just getting a 520 forward swept front axle. I believe it would be a heck of a lot less work and you will have a front end that is capable of whatever you want to do, loader, blower, 60” deck etc. Just my two cents! Share this post Link to post Share on other sites
WheelhorseBob 1,550 #7 Posted November 1, 2020 Based on comparing my C161 and 520 it looks to me like the D series spindles with a slightly longer set of tie rods would work perfectly with a 520 swept axle. The geometry seems close. IDK, I really don’t need a heavier front on the 161 for my use. Just thinking of a way to use the NOS parts I have.... 1 Share this post Link to post Share on other sites
