CwoodHorse 1 #1 Posted October 30, 2020 I was offered a plow blade with unknown history. Will this plow blade with shorter frame shown in photo below fit to "attachamatic" on a 1993 416h? I note that the plow frame has parallel bars, but they don't extend to rear axle. Can the 416h hydraulic lift control height? It appears a loose ink bar is there with the plow, but the connection is not immediately obvious, and I expect some further bits may be missing. The model number tags on the plow and frame are missing, can anyone identify the model number so I can search out further information? Thank you in advance for any insight. 1 Share this post Link to post Share on other sites
Pullstart 68,981 #2 Posted October 30, 2020 I haven’t ever seen that type of frame, my guess is that it might be for some type of vertical shaft Wheel Horse? I would pass on it, unless it’s free. Then, it’ll require some serious rework to fit. 2 Share this post Link to post Share on other sites
peter lena 9,782 #3 Posted October 30, 2020 CWOULDHORSE , agree with pullstart , on the short frame issue , if you can get it cheap , and then get a longer style frame , used , the unbolting and bolting to the steering quadrant to that frame is not that difficult . do your research on , blade matching to the longer frame , if it only turns out to be a frame swap , with w/h parts . that is easy, pete Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #4 Posted October 30, 2020 2 hours ago, CwoodHorse said: I was offered a plow blade with unknown history. Will this plow blade with shorter frame shown in photo below fit to "attachamatic" on a 1993 416h? I note that the plow frame has parallel bars, but they don't extend to rear axle. Can the 416h hydraulic lift control height? It appears a loose ink bar is there with the plow, but the connection is not immediately obvious, and I expect some further bits may be missing. The model number tags on the plow and frame are missing, can anyone identify the model number so I can search out further information? Thank you in advance for any insight. Just like @pullstart said above that one is for a vertical shaft tractor such as the 252, can you make it work? That depends your talents tools and overall capabilities... 1 Share this post Link to post Share on other sites
rlrnot 39 #5 Posted October 30, 2020 (edited) That appears to be a 42" dozer blade, Model 6-7121. I had one a Charger 8, which was a vertical shaft machine. I modified it to fit my 310-8 by using angle iron to extend the rails to the rear axle and removed the attachment uprights. Did that many years ago and still us it to clear my driveway of snow. Edited October 31, 2020 by rlrnot 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,015 #6 Posted October 31, 2020 6-7123 blade replaced 6-7121 and 6-7122 This blade replaced by 6-7124, 66-42BA01, 76-42BA01, 86-42BA01, 96-42BA01 and 06-42BA01 Garry Share this post Link to post Share on other sites
CwoodHorse 1 #7 Posted October 31, 2020 Thank you for the replies. Very helpful. Lots for me to evaluate and research. I will update outcome in a few weeks. Share this post Link to post Share on other sites
