leeave96 496 #1 Posted October 23, 2020 (edited) Here is a video I took from various places around the 520H with rear discharge deck while mowing around my barn. Enjoy! Edited October 23, 2020 by leeave96 Corrected link... 5 1 Share this post Link to post Share on other sites
peter lena 9,895 #2 Posted October 23, 2020 leeave96, thanks for the ride ! I too use r/d decks , prefer them over the s/d decks for a much cleaner discharge and less grass build up. how often do you clean out the bottom side? i regularly do mine and in addition , soak it down with oil lubricant , and let it sit in the sun to dry out and heat up, as well as draw the oil into the metal , to stop rust and kill of the grunge. had any deck spindle bearing or pto mule drive bearing issues ? just asking , made a lubrication change on those , and stopped failures, pete Share this post Link to post Share on other sites
leeave96 496 #3 Posted October 24, 2020 10 hours ago, peter lena said: leeave96, thanks for the ride ! I too use r/d decks , prefer them over the s/d decks for a much cleaner discharge and less grass build up. how often do you clean out the bottom side? i regularly do mine and in addition , soak it down with oil lubricant , and let it sit in the sun to dry out and heat up, as well as draw the oil into the metal , to stop rust and kill of the grunge. had any deck spindle bearing or pto mule drive bearing issues ? just asking , made a lubrication change on those , and stopped failures, pete I’ll clean a deck once a year, in the fall and coat it with slip plate. 1 Share this post Link to post Share on other sites
