Frankenstein 58 213 #126 Posted November 30, 2020 I really wanted to use my original tires on my build but I think they are to far gone. Major cracks and dry rot plus the beads are pretty tore up. What are you guys using for replacements. I did find the Carlisle tires. They look nice. Share this post Link to post Share on other sites
Frankenstein 58 213 #127 Posted November 30, 2020 I wanted to use my original tires on this build but I think they are to far gone. Major cracks and dry rot plus the beads are pretty torn up. I some some Carlisle tires.?? What are you guys using as replacements Share this post Link to post Share on other sites
AMC RULES 37,225 #128 Posted November 30, 2020 https://www.millertire.com/products/lawn-garden-tires/4-00-8/4-80-8-firestone-turf-guide-4-ply/ Share this post Link to post Share on other sites
Frankenstein 58 213 #129 Posted November 30, 2020 Ok great. Thanks. Front tires look great. The Carlisle rear looks closer to my original than the Firestone rear ag tho. Share this post Link to post Share on other sites
oliver2-44 10,943 #130 Posted December 3, 2020 @Frankenstein 58 Sorry somehow I haven't kept up with your thread. if you havent replaced your gas tank filler neck yet, you can get as close to original as feasible filler necks from here. I recently got a couple for my suburban projects. 1 2 Share this post Link to post Share on other sites
Frankenstein 58 213 #131 Posted December 3, 2020 Thanks for the reply. I was reading a lot of old posts over the weekend maybe to many and I did find this. It’s on my Christmas list Share this post Link to post Share on other sites
Frankenstein 58 213 #132 Posted December 5, 2020 Has anyone one just turned their axle and drilled another pin hole 1 1 Share this post Link to post Share on other sites
Frankenstein 58 213 #133 Posted December 31, 2020 Finally some progress. Thanks for heading me in the right direction on this. Should work fine now 5 Share this post Link to post Share on other sites
ebinmaine 74,278 #134 Posted December 31, 2020 2 hours ago, Frankenstein 58 said: Finally some progress. Thanks for heading me in the right direction on this. Should work fine now Looks really really good. Forgive my ignorance cuz I've never done one of those ... is that a de-solder and resolder? Share this post Link to post Share on other sites
Frankenstein 58 213 #135 Posted December 31, 2020 No ignorance. Yes it is. It actually was pretty easy. 2 Share this post Link to post Share on other sites
Frankenstein 58 213 #136 Posted December 31, 2020 2 minutes to fix. 2 weeks to clean out tank Share this post Link to post Share on other sites
Lane Ranger 11,589 #137 Posted December 31, 2020 On 12/5/2020 at 3:09 PM, Frankenstein 58 said: Has anyone one just turned their axle and drilled another pin hole that has been done before and Steveasaurus mentions this in one of his three piece transmission rebuild threads. 1 Share this post Link to post Share on other sites
Frankenstein 58 213 #138 Posted December 31, 2020 Thanks I will try and find it Share this post Link to post Share on other sites
oliver2-44 10,943 #139 Posted January 2, 2021 (edited) I turned and re-drilled a set as Steve’s thread had mention was an option. To help me center in the drill press vice I Ran the drill bit into the existing hole and got the vice centered up. The I swapped the shaft around and put a fowl in the existing hole. I put a vertical eleven on the dowel and that got me back to the same center in the vice. Be careful to not get the hole to far onto the shaft. You can have trouble with the ends of the shafts hitting in the differential. Edited January 4, 2021 by oliver2-44 Share this post Link to post Share on other sites
Frankenstein 58 213 #140 Posted January 2, 2021 Ok thanks for the heads up Share this post Link to post Share on other sites
Frankenstein 58 213 #141 Posted January 9, 2021 Got holes drilled on the other side of the axles and so it seems two newly made ones appeared my nephew decided he wanted to make new ones 2 Share this post Link to post Share on other sites
DennisThornton 4,771 #142 Posted January 9, 2021 On 10/19/2020 at 10:24 AM, bottjernat1 said: Here is original sales literature for the rj58 and 59. I have this in a double sided glass frame Awesome! If this is NOT in this forum's collection of files perhaps you would consider copying and uploading. Share this post Link to post Share on other sites
Frankenstein 58 213 #143 Posted April 24, 2021 New tires and tubes. New rear axles and repaired front spindle. Trans rebuilt with new bearings bushings and seals. Put dual axel seals on just to make sure they don’t leak. Still a ways to go but at least it looks like a tractor again 4 1 1 Share this post Link to post Share on other sites
Frankenstein 58 213 #144 Posted June 6, 2021 It lives.! It’s running and moving. Thanks everyone for their help on this. It’s been a lot of fun. IMG_2099.MOV IMG_2101.MOV 1 2 Share this post Link to post Share on other sites
AMC RULES 37,225 #145 Posted June 6, 2021 Nice W-H work! Love that green! Share this post Link to post Share on other sites
Frankenstein 58 213 #146 Posted June 6, 2021 Thanks. And I do believe it’s staying that color 1 Share this post Link to post Share on other sites
